Truck 305
Old Apr 20, 2012 | 11:24 PM
gregl316's Avatar
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
Truck 305
Ok here's a post everyone has prob seen befor. I have searched and haven't found my answer so I am going to ask directly. I have a 91 Camaro convertible with as you know a 305 TBI and a 700r4. It has 163000 for miles on it but it is running awsom. It does blow some blue smoke when you first start it in the morning. It doesn't even leak a drop. Well I have found a very low milage 1988 305. It only has 35k on it and it is complete and I mean drop it in complete. But here's my delema it is out of a truck. Is there any difference? Do I need a new cam to make it work in my car? I really don't want to spend the money. The motor is only 400 but if I have to put a bunch of money into it that blowes the good deal. So if anyone knows what should I do? Is it a good deal? Or should I save my money and put a 350 in it.
Old Apr 21, 2012 | 08:42 AM
one92rs's Avatar
Car: SOLD!!!!!
Re: Truck 305
you will need your oil pan. you might look to see where the sensors are mounted and check yours. and you need to see if the tbi has the right throttle arm mounting for your cables.
Old Apr 21, 2012 | 12:25 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: Truck 305
I think the oil pan is the same
Old Apr 21, 2012 | 12:55 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Truck 305
Truck oil pan will fit just fine, if it's from a half ton 2WD pickup. Truck cam will also drive just fine, but isn't roller-lifter like the car version, so I'd save the cam, lifters, pushrods and front thrust plate from your original engine. Those roller lifters are easily disassembled, cleaned, reassembled and reused if they're not damaged. But don't try putting them on the truck cam.
Old Apr 21, 2012 | 01:24 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: Truck 305
not from a truck to a camaro or firebird it isnt. at least the one i have had were not.
Old Apr 21, 2012 | 08:52 PM
gregl316's Avatar
Re: Truck 305
I've been talked out of it. I will just keep the engine and not buy the new one. When this one finally goes I'll stick a 350 in it. This give me time to find a good one to rebuild. Now can I put my TBI on a LT1 motor? Should I just find a TBI 350 and rebuild that. Or can I use an old carberated motor and put mt TBI on that? I want to keep the injection and all the computer stuff and make it as stock as possible.
jhawkeye
May 25, 2022 06:33 PM
gta90
Sep 15, 2015 04:00 PM
DJanes97
Sep 1, 2015 02:55 PM
mustangman65_79
Aug 8, 2015 01:18 AM
