5.0 in 91 Vert intermittent stalling issue
Old May 22, 2012 | 10:35 PM
joecool108's Avatar
Car: 91 Vert, 69 SS, 91 Coupe
Engine: V8, V8, V6
Transmission: Auto, Auto, 5 speed
Ok gang this is driving me crazy. 5 liter TBI all stock car runs fine and then at no apparrent rime or reason it will stall and die. When I try to restart, it stumbles, runs rough, and chokes itself out. If I try to feather the throttle or try to give it gas, it stalls. If I dont touch the accellerator, it will idle rough, erractic then die again. After about 5 minutes, it restarts and the car runs fine.
This has happened to me at least once a day over the last few days.
Code 54 - so I replaced FP relay on firewall. I also put new fuel filter in.
Any ideas? Seems to be fuel problem, but not sure.
Help!
Old May 23, 2012 | 09:48 AM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
Re: 5.0 in 91 Vert intermittent stalling issue
Could be trash in the fuel tank clogging up the pump pickup. However, your issue could be caused by many things so it's hard to say exactly what it is that's causing it.
Old May 23, 2012 | 09:56 AM
Ronny's Avatar
I would monitor FP under load. Ideally you would duct tape gauge on windshield and have passanger witness.
Old May 31, 2012 | 08:52 PM
joecool108's Avatar
Engine: V8, V8, V6
ok here is what i have done over the last few days:
1) Changed gas caps
2) Installed new fuel filter
3) Cleared codes
4) Installed new FP relay
5) Cleaned IAC
Car only stalls and wont restart in the afternoon on the way home from work (approx 30 mile trip) and it is fine in the morning.. Crazy stuff!!!
Help!
Cornholio7979
Sep 20, 2018 02:31 AM
jklein337
Sep 19, 2018 06:23 PM
777Shock777
Oct 29, 2015 04:30 PM
ron reece
Southern California Area
Oct 7, 2015 01:11 PM
Bryan F
Aug 18, 2015 02:28 PM
