injector swap
Old May 25, 2012 | 12:25 AM
rigsboo's Avatar
injector swap
ok so im new here and just got a 92 rs well it has 19lb injectors i belive well its tbi wich is 2 injectors (correct me if im wrong) if i put a Motorvation 192012-T chip on it and 24lb injectors would it run right? would i notice a big diffrence? if i didnt switch injectors would i notice any diffrence with throttle response with the chip? if 24lb injects is to much would 21lbs with the chip make a diffrence and still run right?
Old May 25, 2012 | 01:38 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: injector swap
On a mostly stock L03 you should be running 40 lb/hr
Old May 25, 2012 | 08:18 AM
rigsboo's Avatar
Re: injector swap
i thought that they were 19lbs stock...on summit racing if i search by vehicle i can only find up to 24lbs
Old May 25, 2012 | 02:22 PM
Engine: Lb9
Transmission: M20
Re: injector swap
It looks like you must be looking at tpi mpfi, for a lb9 they are 19#hr and L98 22#hr.
A tbi L03 would use these
http://www.summitracing.com/parts/SMP-TJ4T/
Old May 25, 2012 | 03:56 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: injector swap
If you have a relatively stock engine. You do not need an injector upgrade. What you can upgrade and get a few more HP out of your engine is the fuel pressure regulator. Their is a thread where you can make your stock regulator adjustable. Or you can purchase an adjustable fuel pressure regulator for it. I think Jet, and motorvation makes them.
Other than that. You can do all the ultimate tbi mods.
Put headers and full exhaust on the car
Street Lethal
Apr 30, 2019 12:14 PM
gta90
Sep 15, 2015 04:00 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Jae992
Aug 27, 2015 09:07 AM
tmellott89
Aug 16, 2015 02:58 PM
