cam help?
Old May 25, 2012 | 12:35 AM
rigsboo's Avatar
cam help?
what is the best cam for the 416 heads (5.0 ho heads) with a chip everything else is stock
Old May 25, 2012 | 05:43 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: cam help?
How about a little-bit more information:
Stock 305 with 416 head (year)? TBI injection?
Did re-work heads for new springs?? Do you know maximum valve lift?
trany (5M or 4A)?
Old May 26, 2012 | 11:04 PM
rigsboo's Avatar
Re: cam help?
305 stock with tbi in a 1992 its a automatic and heres the info http://www.ebay.com/itm/PERFORMANCE-...a8c766&vxp=mtr i was gonna get theese but im not sure yet
Old May 28, 2012 | 11:43 AM
RFmaster's Avatar
Car: 75 Beast
Re: cam help?
I looked at the listing - and here is the problem :
"Professionally rebuilt pair of small block Chevrolet heads. Casting number is: 416. These heads do have the accessory holes. Heads fit all small block Chevrolet engines, 283 - 400. If you need them drilled for steam holes for the Chevrolet 400 we will do that for you at no extra charge. Heads have the 64 CC chambers."
and
"Heads are assembled with new stainless 2.02 swirl polished intake valves
Heads are assembled with new stainless 1.60 swirl polished exhaust valves"
The "416" casting number that I know of (14014416) were used on 80-85 HO305 usually come with 55 to 59 cc chamber and have 1.84"/1.50" valves..
On a stock bottom end 305 you'll need to use 55-58cc heads to maintain compression. If you move to 64 cc chamber head you will loose 0.75 of CR which is not good for performance (going from 9.0:1 to 8.25:1 CR will not win too many races!). I would contact the listing owner and verify complete casting number and combustion chamber size.
Over the years there have been a lot debates regarding use of 2.02/1.60 in 305's. I am not going to open this can of worms - the debate still rages on! FWIW I would upgrade stock 416 to 1.94/1.50 valves and make sure that springs and head can handle 0.550 valve lift for possible future cam upgrades.
//RF
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
