Car is suffering from Extreamly high idle and no idle at all. Also running rich.
Old Jun 18, 2012 | 03:46 PM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
My RS 5.0 is starting back up with the idle problems again. It doesn't like to start up without a little gas. Sometimes the car won't idle by its self, and I have to give it a bit of gas and idle it manually at approx 1200rpms till it warms up. After it warms up it idles at around 1000rpm When it's like this I often find myself stalling when turning into an intersection or while turning out of my drive way.
When it's not like that, it's starts up and idles at 2500-2800rpm until it warms up (at least accoring to my crap speedometer), and even then its between 1200-1500rpm. When it is like this It doesn't stall.
I have recently changed the oil, and given it a full tune up with Rapid Fire spark plugs, and I haven't modded the engine in any way. It was running really good right after I gave it the tune up, and it stopped running rich. About 3-5 weeks later it started with the idling problems and it's running on the rich side now.
Anyone got any advice for me? Thanks!
Old Jun 18, 2012 | 03:53 PM
Ronny's Avatar
Re: Car is suffering from Extreamly high idle and no idle at all. Also running rich.
Vac leak? If not is IAC functional? Throttle shaft to TB worn?
Idleing at 2800 means it is getting air from some source other thanopened butterfly..
Old Jun 19, 2012 | 07:19 PM
KrazyFirst's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: WC t5
Axle/Gears: Stock
Definitely check all vacuum connection, had the same problem with not having the vacuum connections hooked up right, and when i did, they were cracked and leaking, swapped out to new lines and all good. Let me know if it helps.
Old Jun 19, 2012 | 08:12 PM
one92rs's Avatar
Car: SOLD!!!!!
no codes????
Old Jun 19, 2012 | 08:18 PM
Car: 1992 Camaro RS
I'll def. check the vac lines. Don't know how to read codes 92. Sorry. Not sure where those show anyway.
Old Jun 19, 2012 | 08:32 PM
one92rs's Avatar
Car: SOLD!!!!!
look above the tach on the dash when the car is running.
Old Jun 19, 2012 | 10:20 PM
Car: 1992 Camaro RS
You mean in the Engine Check light and IMFL Rest area? Are those the codes your thinking of?
Old Jun 19, 2012 | 11:47 PM
gregl316's Avatar
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
Mine was doing the same thing. I found several vacuum leaks and I replaced the TPS and poof all better. I love my car but I miss a carb.
Old Jun 20, 2012 | 05:51 AM
one92rs's Avatar
Car: SOLD!!!!!
after you start the car and it is running does the check engine light stay on or go out.
Old Jun 20, 2012 | 11:07 AM
Ronny's Avatar
Take car to an AutoZone or Advance auto and have them check codes....Free
Old Jun 20, 2012 | 04:01 PM
Car: 1992 Camaro RS
Sometimes it stays on for a little while and then goes away. I'll take it to Auto Zone to check for codes.
Old Jun 20, 2012 | 05:14 PM
KrazyFirst's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: WC t5
Axle/Gears: Stock
When it goes on and off, its normally a sensor. My map sensor did this and made it so the car idled like ****. All due to me swapping the engine and didnt hook up the vacuum lines correctly, and leaving one on the TB open... not my proudest moment.
Old Jun 22, 2012 | 10:59 AM
torque_is_good's Avatar
they can't help you because you have an OBD1 system
you need to simply use a paper clip on the ALDL port and read the flashing codes
Old Jun 22, 2012 | 11:15 AM
Car: 1992 Camaro RS
Forgive my incompitance. ALDL port?
Old Jun 22, 2012 | 12:06 PM
asking is learning, nothing wrong with that
I may be acronym challenged however I believe it's
Assembly
Line
Diagnostic
Link
if you are in the drivers seat it should be near your right knee
try doing a search here on this site for flashing codes but, and this is memory because I have not done it for a while so double check me to be safe
the top 2 right pins get jumpered with a paper clip or piece of wire
turn key to run, CEL light should flash once, then twice, and then move on to any other codes such as flash 4 times and then 3 times
it will keep flashing as many codes as were stored and then return back to 12 and start all over again.......or is it 22?
that's why you need to confirm my memory
Old Jun 22, 2012 | 01:06 PM
Car: 1992 Camaro RS
Thanks. I'll try that later.
Old Jul 26, 2012 | 06:22 PM
Car: 1992 Camaro RS
Well, car is getting a bit wrse now. I little tiny bit of white smoke is coming out of the tail pipes at start up and often when warming up, and the idle is even higher. I'm going to check the codes tomorrow and do a sea foam treat ment to try and clear any cloged or gunked vacume lines/fuel system.
Old Jul 29, 2012 | 07:24 PM
KINGJOEL's Avatar
Engine: 3.1
I bought a 91 Cmaro with 3.1, It died every time I stopped. There was black soot in the tailpipes so I replaced the O2 sensor, that fixed it.
Old Jul 29, 2012 | 08:34 PM
Car: 1992 Camaro RS
Yah. Just read the codes. 12, 13, 11, 14, posible 21 (I don't remember reading this but it would make sense with the symptoms I've experianced and the code 23), 22, 23, 24, and maybe a 25. Most of those can be ignored. But, code 23 (Throttle body position sensor error), would explain the high/off idle. And the Oxygen senor error (code 13), would also explain allot. The Oxy sensor I can take care of, the throttle body position sensor I have no experiance with.
Old Jul 30, 2012 | 05:20 PM
one92rs's Avatar
Car: SOLD!!!!!
13 and 14 yes you need them. 12 means ecm is working. 21, 22,23,24 these all need to be taken care of.
Old Aug 1, 2012 | 06:50 PM
Car: 1992 Camaro RS
How do I take care of the the throttle body position sensor?
Old Aug 1, 2012 | 07:39 PM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
the tps is located to the right of the IAC on the throttle body, replace it and the code should clear if that's what was causing the issue
Old Aug 1, 2012 | 10:03 PM
one92rs's Avatar
Car: SOLD!!!!!
do you have a meter?? remove the old one and install the new one with the battery disconnected. this all sure seems like a harness issue. like a feww bad grounds and the pink and black wire that gives ignition power all over the engine has a break in it.
Old Aug 2, 2012 | 09:18 AM
Ronny's Avatar
Do you have a multi meter? If so you can check TPS with a jumper/adapter made by yourself to attach meter. Look for smooth voltage linear increase from .50v or so to 4.5 as you open throttle. key on engine off. Somewhere here is the diagram of the leads you need to jump to. I forget.
Old Aug 9, 2012 | 05:54 PM
Car: 1992 Camaro RS
Yes. I have a meter. Wait, what? That whole last bit confuses me. When you start getting into car electronics my brain blows a fuze.
Old Aug 13, 2012 | 04:00 PM
Ronny's Avatar
You attach the multi meter to 2 of the 3 leads to TPS. with key on engine off or engine on it will read .50 or so at throttle closed. Then sloooowlllly open the butterflies and it will smmooothly increase in V's to 4.5. If it is erratic on the opening of BF's then TPS may be defective.
Old Aug 13, 2012 | 11:22 PM
Car: 1992 Camaro RS
That I can understand. Thanks mate.
Old Aug 20, 2012 | 04:43 PM
Car: 1992 Camaro RS
Hmmm. I got confused somewhere. Can someone tell me where the TPS is, just so I can be sure I'm doing this right.
Old Aug 20, 2012 | 04:50 PM
Ronny's Avatar
attached to side of the throttle body where the linkage is. drivers side
Old Aug 20, 2012 | 04:57 PM
Car: 1992 Camaro RS
Ah.
Old Aug 20, 2012 | 05:21 PM
Car: 1992 Camaro RS
uhh. For some reason I'm not seeing it.
Old Aug 24, 2012 | 10:01 PM
Car: 1992 Camaro RS
I can't find it.
Old Aug 24, 2012 | 11:34 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
you should post up a picture of what your seeing and we can highlight it for you
Old Aug 25, 2012 | 01:18 AM
lozantius82's Avatar
Car: 89 Camaro Iroc Z
Transmission: MK6 World Class T5
Axle/Gears: 9 bolt had 3.45's, now 3.27 gears
I can't find it.
It should be right in the area where i circled red. There should be a black sensor with two torx screws that attach it to the passenger side of the throttle body. Good luck!!!
Attached Thumbnails Car is suffering from Extreamly high idle and no idle at all. Also running rich.-pic.jpg
Old Aug 25, 2012 | 09:37 AM
Caveman305's Avatar
Engine: L03, LB9
Yup, standing infront of the car, it's on the pass side of the throttle body, it looks kinda like a black half circle, has a connector plugged into it
Old Aug 25, 2012 | 01:42 PM
Car: 1992 Camaro RS
Thank you. You can see where I'm getting confused. I know where that sensor is. It's EXACTLY WHERE I THOUGHT IT WAS. On the PASSENGER side. Uhg. Alright. Lets try this again.
Old Aug 27, 2012 | 09:13 AM
Ronny's Avatar
Sorry mine was on drivers side but that is a Vette. My 7.4L TB is in fact on pass side!
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
