How to remove breather hose
Old Jun 20, 2012 | 08:57 PM
spykey's Avatar
Car: 1991 camaro rs vert
Engine: 305 tbi
Transmission: 400
I was searching for this but didnt have any luck. I was wondering how to remove the passenger side valve breather bent hose. It does wiggle and spin around, but when i tug it, it seems to be stuck. Anything special i need to do? Thanks for the help.
Old Jun 21, 2012 | 08:31 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: How to remove breather hose
Mine just pulls out. I just twist it while pulling on it. Should slide out.If its still giving you trouble try to pour a little oil around it so the sides of the hose will slide out easier.If your going to be putting a aftermarket breather on it be sure to use a small amount of oil around the inside wall of the rubber hole and some on the outside rim of the breather and be careful not to push the rubber piece around the hole inside the valve cover while your doing it.
Old Jun 21, 2012 | 10:34 PM
spykey's Avatar
Engine: 305 tbi
Transmission: 400
Just what I was looking for. Thanks alot I really appreciate it!
Old Sep 23, 2014 | 04:53 AM
Dionw's Avatar
I know this is an old thread but this is just the information that I needed. Thanks!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stroopwafel
Sep 11, 2015 06:38 AM
greenyone
Sep 8, 2015 08:41 PM
