should i get the ac delco ep 241 fuel pump?
Old Jun 28, 2012 | 04:40 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
im fairly sure my pump has gone bad.it won't run.when you crank it it barely idles surging up and down.i changed the tbi unit to another one i have.no change.it runs good for a moment when gas is poured into the tbi.i put a guage at the new filter and and cranked it up.it had four pounds of pressure that dropped immediatly when it stalled.so i thought if im going to change the pump id use the tpi pump for future mods.is it completely bolt in?has anyone had problems doing this?thanks.
who carries these?the pumps at advance auto have different model numbers.the bosch pump got good reviews.any opinions on them?
Old Jun 28, 2012 | 07:32 PM
zenish's Avatar
Engine: 305 tbi
Re: should i get the ac delco ep 241 fuel pump?
my fuel pump relay plug is a little scorched.that may be the problem.
Old Jun 28, 2012 | 08:50 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Yes get that cleaned up and let us know if it worked for you.
Old Jun 28, 2012 | 09:21 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
if you need a pump. even for the tbi. the ep241 pump is a must do upgrade IMO.
Old Jun 29, 2012 | 03:23 PM
gregl316's Avatar
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
I got the EP381 is that cool? I bought it from eBay and only paid 42.50. It was a buy-it-now auction with make offer option. He took my offer rite off I should have offered less.
Old Jun 29, 2012 | 04:15 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
I do not know anything about that pump.
Old Jun 29, 2012 | 07:40 PM
imeredith's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
If your plug is scorched, you may want to figure out why before just replacing it. Usually things like that are caused by a short in the circuit somewhere, although I'm thinking a failing fuel pump could also cause it. If possible, please post a few good quality pics of the burnt plug.
Old Jun 30, 2012 | 11:57 AM
Schurkey's Avatar
GM/Delco/Delphi has more fuel pump part numbers than you can shake a stick at; and absolutely no guidance on WHAT is different among them.
All I know is that the original fuel pump in my truck had a 3/8 outlet to match the 3/8 tubing of the sending unit assembly, and the EP-241 I replaced it with had a 5/16 outlet. I had fun finding a suitable hose to fit the larger-diameter tubing while still sealing on the smaller fuel pump nozzle.
Old Jun 30, 2012 | 06:29 PM
one92rs's Avatar
Car: SOLD!!!!!
ep381 is for the later vortec engines that run near 60 psi. that pump is rated for 70 psi. not sure if it will work but it could.
Old Jun 30, 2012 | 07:15 PM
zenish's Avatar
Engine: 305 tbi
i found the problem.i noticed that the gas tank was all scratched up while removing it.apparently someone replaced the fuel pump before and used the one that comes with the bad hose.the hose between the pump and sender plate had burst.i read somewhere that some replacement pumps come with a bad hose.im going to change the pump anyway.the problem is finding as local source for ac delco parts.
Old Jun 30, 2012 | 09:18 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
well the pump supplies the volume the regulator determines the pressure. but too much volume and the stock return system cannot keep up. I would run the pump that people recomend instead of opting for a cheaper option that may not work. especially with the amount of work it takes to drop the tank out.
Old Jun 30, 2012 | 10:25 PM
one92rs's Avatar
Car: SOLD!!!!!
very true. restriction causes pressure. im sure it can be toned down to work. just not sure if the system will handle it with a stock regulator.
Old Jul 1, 2012 | 09:59 AM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
I ran a Walbro 255 for 7 years and it died. I'm debating the ep241 vs ep381 now.
Did you check for codes? My car is throwing a code 54.
Old Jul 1, 2012 | 04:22 PM
morgsie's Avatar
This is the vortec pump. Even higher output than the TPI. You should be fine.
Old Jul 8, 2012 | 10:45 AM
zenish's Avatar
Engine: 305 tbi
i installed the ep241 pump.the problem was a busted hose in the tank.i could have just changed the hose but i hope to swap in a 5.3 later.no problems using the ep 241 pump so far but i lost the gas guage during the swap.good thing i fixed the trip odometer a while back.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
