Got an odd one
Old Jun 28, 2012 | 08:59 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
Got an odd one
So I just got a 91 firebird l03 auto the car idles fine but when I hit the gas the ses comes on and runs bad like it is missing. Then in 2 seconds or so the light goes away and runs fine, as you drive it goes back and forth.
So I have checked
Timing @ o
Fuel psi 14
Tps .58-4.48
Map, iac,esc,icm,air temp and all grounds are good
And I can not pull a code both my scan tool will not link and when I jump it I get me no codes
O and it has a jet stag 2 in it and the car is all stock
Any input would be helpful thanks Tyler
Old Jun 29, 2012 | 12:58 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: Got an odd one
Check fuel pressure during idle and while it is stumbling. If the fuel pressure remains steady this would rule out fuel delivery issues for the most part. The other possibility is a bad dizzy - reluctor coil is intermittent or a stator has loose magnet. Pop the cap off and see if the base very rusty looking. Moisture accumulation inside dizzy is common due to clogged vents. Most of the times swapping in a rebuilt unit cures these mysterious stumbles, loss of power...
//RF
Old Jul 6, 2012 | 01:57 PM
Camaro-Drew's Avatar
Car: 92 rs Camaro
Engine: no engine now, some sorta sbc soon!
Transmission: none now, built auto oneday!
Axle/Gears: stock now, 9" one day!!
Re: Got an odd one
My camaro had this same exact problem, couldn't figure it out for the life of me. I ended up taking it to the dealer (been a diesel mechanic for over a decade so it was real hard to admit to myself I couldn't figure it out, swallowed my pride and took it in), they diagnosed it as a bad distributer. So I took it home and dropped in a brand new MSD unit, still same exact problem. (stupid dealership mechanic's, paid for a diagnosis and they just guess) I ended up going a totally different direction with the car, threw away the 305 and gutted the electronics (in the process of turning into a track only drag car) To this day that problem puzzles me and I still wonder what it could have been...Hope you find the answers, I'll be watching this closely!!
p/s: this was a few years back, wish I would've known about 3go at the time!!
Old Jul 6, 2012 | 06:12 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Got an odd one
bad ground for ecm. bad ecm. distributor. hard to be 100% sure.
Old Jul 7, 2012 | 11:29 PM
Schurkey's Avatar
Re: Got an odd one
I'd think that is a clue in itself.
ALDL mis-wired?
SES light bulb burned out?
I'd be checking everything in the ALDL circuit.
Old Jul 9, 2012 | 04:14 PM
Engine: 5.8
Re: Got an odd one
it was the tps my meater coulod not read it but it was jumping back to .35 when at part open. thanks guys
Mark_ZZ3
May 24, 2018 01:02 PM
Stryker412
Sep 20, 2015 06:59 PM
Fronzizzle
Sep 8, 2015 12:10 PM
Warlocksirix
Sep 3, 2015 12:26 PM
BlackphantomZ28
Aug 31, 2015 11:19 AM
