anitfeeze leaking after intake change
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
ok i put my intake an chrome valve covers today . well after getting it all together . i started addinfg anti freeze an it start leaking mid way back under the car ? any ideas ? do these cars have trans cooolers ? it was dark by the time this problem showed up . any help would be appriciated . here a pick of it after i got the intake on an valve covers on . :
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: anitfeeze leaking after intake change
mid way back under the car? leaking from the rear intake port area? was their a leak before you changed the intake?
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Water only runs through the front of the intake, not the rear. Leaks can travel away from thier originating point, but unless this car is parked with the front in a "way up" attitute, my guess is that the leak is somewhere else, like possibly the heater hoses.
Edit: Come to think of it, although the intake does not pass water, it does in fact seal the ports off from the rear of the heads. Potential for a leak there.
Engine: l98 tpi
Axle/Gears: 2.77
no leaks until after i changed the intake .the car wasn't jacked up at all
i've worked on alot of cars but this a first for me to . was to dark last night to search for the problem so i jus thought i'd ask around . i guess if i didn't get it sealed up good it could be running back down thr tranny an dripping that far back . damn i hate to have to take this thing back off .
Engine: gone
Transmission: gone
Axle/Gears: gone
Engine: l98 tpi
Axle/Gears: 2.77
i pulled the intake again an put black rtv on both sides of the gasket around every hole por an a lot thicker on the ends . i read some where to let it setup for 24 hr before adding water an trying to run it . so we'll see tommmorrow .
it was leaking on the back end of the intake . guess i''ll change the oil in the morning also before starting it .lol
Engine: l98 tpi
Axle/Gears: 2.77
i do have a questin tho .this manifold only has the one prot for vacum . can i tee int that line for my brakes or can i use the pvc vacum line for brakes ?
Part number? I need that exact fitting. Part stores up here stock very little "one off" things like this so I just order stuff from summit.
EDIT: Think I found it... Performance Stainless Steel p/n 1044.
Engine: gone
Transmission: gone
Axle/Gears: gone
good info. One92rs.
Freaky glad ya found the leak and fixed it.
Engine: l98 tpi
Axle/Gears: 2.77
thanks guys for all the help . she'a alive . now i need to do a oil change an reflush the tradiater an refill it again . she's idling a little higher with this intake on . i only let it run for a min just to make sure it would start . changing all fluids tommorrow an start the tuning process again .lol
Engine: gone
Transmission: gone
Axle/Gears: gone
no coolant throws the cts sensor off that would change idle some.
Engine: gone
Transmission: gone
Axle/Gears: gone
ohh okay I was thinking you just fired it up for a minute with nothing in it. gotcha..
Engine: l98 tpi
Axle/Gears: 2.77
but today after the oil , water change . i went for a ride . no gauge cluster working . my tach on my ebl is working but not the speedo . an get this when i turn on the headlights the buzzer goes off like i left them on an shut the car off with the keys out . wtf ?
Hellbillydeluxe
Sep 22, 2015 09:58 PM
