Hydrocarbons Be Gone(Or Just Lessen)
Old Jul 16, 2012 | 10:06 PM
NeNick95's Avatar
Engine: 5.0 TBI
Okay I changed everything that air,fuel,emissions.Except the 02 sensor.The guy that does an inspection on the car when failed said that at idle the car releases more of the hydrocarbons so i replaced the EGR and it went done some but not enough.So now i have this fuel cleaner/adder called SNAP, got it from a frequent guest at the body shop.So im wondering is this stuff called SNAP good or should i try drygas or something else.Also put the timing down stock is 6 degree put it at 3 degree so im putting it at 0 degrees. Any helpful tips please type in.
Attached Thumbnails Hydrocarbons Be Gone(Or Just Lessen)-img_20120715_215118.jpg   Hydrocarbons Be Gone(Or Just Lessen)-img_20120715_215138.jpg
Old Jul 17, 2012 | 10:28 PM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
Re: Hydrocarbons Be Gone(Or Just Lessen)
Don't know anything about SNAP, but I have used iso-heet to help lower HC in order to pass sniffer test. Couple of bottles in 3/4 tank of fuel, Worked good.
Check out this thread https://www.thirdgen.org/forums/tbi/...mmissions.html
Old Jul 18, 2012 | 01:51 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
well timing is supposed to be at 0* anyway.
Hydro carbons are unburnt fuel. Does the motor run smoothe? how is the tune up? and are the plugs really good or you just think they are good?
Old Jul 18, 2012 | 09:51 PM
NeNick95's Avatar
Engine: 5.0 TBI
The motor runs nice and smooth I did a complete tune up a couple months back.April and hasn't moved since May got ticket with no plates so was parked.
Tune UP Items Changed:
EGR,Oil, oil filter,fuel pump,fuel filter,ecm(needed),spark plugs, spark plug wires, module,IAC, map ,tps, cap and rotor,coil,smog pump and some vaccum hoses. Now im just going to buy a 02 sensor( only 19 bucks).The plugs are Bosch do you prefer a brand I've heard rapid-fire spark plugs by AC/Delco camaro guys prefer?I'll take almost the oddest advice right now.
amcnellis
Sep 16, 2015 04:16 PM
Dano 00TA
Jul 17, 2003 09:14 AM
Mark A Shields
May 30, 2001 08:17 AM
BrianB
May 21, 2001 10:29 PM
88transam5.0
May 3, 2001 12:34 AM
