Fuel pressure check
Old Jul 23, 2012 | 06:55 PM
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
Fuel pressure check
If I have suspision of my fuel pump on its way out can I check the fuel pressure in P or N even tho symptoms occure in OD,D,2nd, 1st gear? (I have no one to hold the brake in drive), I believe the fuel PSI should be 13psi but I fogot what line it goes to on the TB. Any help on this will be appreciated thnx.
Old Jul 23, 2012 | 07:33 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Fuel pressure check
Service fuel pressure is 9 - 13 psi for 3rd gen TBI setups. A quick test is to do this:
Connect the fuel pressure gauge to the larger of the lines going to the TBI unit. On a warmed up engine, in park or neutral, first check that the fuel pressure is within spec (9-13 psi).
Then glue an eye-ball to the gauge needle. Whack the throttle wide open and hold for a moment (don't over rev the engine).
If during this WOT moment, if the gauge drops even a single psi, the pump isn't keeping up.
RBob.
Old Jul 23, 2012 | 07:43 PM
Car: 92 Camaro RS
Engine: 305 TBI
Perfect, thank you.
Old Jul 25, 2012 | 12:42 PM
Car: 92 Camaro RS
Engine: 305 TBI
Im trying to get the TB adaptor on but it seems I cannot screw it in due to the Intake Manifold being in way, and the fuel line seems like it is too short to fit inside the adaptor? any advice? do I have the wrong adaptor?...it is T shape.
Old Jul 25, 2012 | 01:29 PM
Car: 92 Camaro RS
Engine: 305 TBI
found it, disregard my last, you can connect it near the Driver headlight there is a rubber line there.
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
