Code 53 vats?
Old Sep 20, 2012 | 12:13 PM
xavier_pr84's Avatar
Code 53 vats?
When I first got my camaro it was horrible 211,000 miles high beams weren't working window didn't row down on drivers side no exhaust bad fuel pump bad speedometer headlights on right didn't work it was a nightmare. Car now is a lot better rebuilt engine all light fixed including high beams replaced fuel pump fixes speedometer and window all on my own except engine rebuilt thanks to this site. Now the camaro is acting up again it started after I went to go get my haircut it was giving me trouble starting the starter sounded like it didn't have any power and was killing the battery thankfully it turned on and I got home . After I ate supper I turned the car on and after a sec it stalled . It did that 3 times and now it cranks but will not start also I got two codes 33 and 53 I know 33 is egr soloniud and 53 I believe is the vats system because the starter runs but it doesn't turn it on. Where do I begine
Old Oct 25, 2012 | 03:25 PM
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
Re: Code 53 vats?
You ever figure this out? My son has a 91 with code 53. I was thinking it had to do with the VATS.
Old Oct 25, 2012 | 06:05 PM
Re: Code 53 vats?
It was actually a blown fuze for me that. Was it
Old Nov 2, 2012 | 02:15 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Code 53 vats?
When its the VATS system all the miscellaneous items radio,lights,etc.will work but other than that you will get nothing,no engine trying to start,no click ,absolutely nothing.When you think it may be VATS than there is a 5 minute waiting period that must be done between attempts or your wasting your time.If it is the VATS system acting up at random times then I suggest a "VATS bypass". Type "VATS bypass" into the search feature on this site and you should get all the information you want on the subject.
Old Nov 3, 2012 | 07:23 AM
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
Re: Code 53 vats?
I did the "resistor thing" and the car now starts every time.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
