Need help with iac reseting
Old Oct 2, 2012 | 08:34 PM
xavier_pr84's Avatar
Hi to all . I have a 92 camaro rs 305 tbi that is having high rpms on start 3500 and stays between 1500 and 2500 on park an on drive between 1700 and 1500. This is fairly annoying because its burning my precise fuel that's expensive as it is . Now I have read a great tutorial on the site which is here https://www.thirdgen.org/tpimod2 but I ran into an issue. The idle speed torx screw section where you turn it clock wise to raise the rpm and counter clockwise to lower well the throttle doesn't go all the way back there's still a gap Any suggestions on my issue would be appreciated thank you .
in the picture you can clearly see the gap
Old Oct 3, 2012 | 01:14 PM
Ronny's Avatar
Re: Need help with iac reseting
Can you look down the TB to see the IAC cycle? I recall it cycles every time at key on.
Even if stuck wide open I doubt it will idle 3500 rpms. seems like a huge vac leak.
Old Oct 7, 2012 | 08:29 AM
cant be a vac leak i replaced all the hoses or maybe it is. how dp i check for this vac leak?
Old Oct 7, 2012 | 08:25 PM
kauboy's Avatar
Car: 83 Z28 Crossfire
Check the throttle body base gasket. You might find a chunk missing = vac leak common problem.
Old Oct 9, 2012 | 12:08 PM
I just checked it last night I actually took the whole thing out and cleaned it was really junky and dirty but no difference . Here's a video .
Old Oct 9, 2012 | 01:31 PM
Ronny's Avatar
Only way it can idle that high is with IAC setting incorrect or a vac leak
Did you inspect or replace all vac lines incl the brake booster. Could be a crack not detached which sometimes happens.
Old Nov 9, 2012 | 09:36 PM
ImBrandon's Avatar
Car: 1991 Pontiac Trans Am
Axle/Gears: 3:42
check your fuel pressure I think that can cause a high idle.
Old Nov 10, 2012 | 09:43 AM
Damon's Avatar
Your tach is reading wrong. The free rev shooting up over 7000 RPMs..... nah. Not in a million years could you get a stock TBI motor to rev anywhere near that high. Plus the ECM has a fuel shut-off that would kick in well below that point.
What is indicated on the tach as ~2000 sounds like about 800 or so to my ear.
Old Nov 10, 2012 | 03:10 PM
ricklovin93's Avatar
Car: 1988 camaro base coupe
Engine: 305 LO3
Transmission: gm 700-r4
typical shitty unreliable guages
Old Nov 11, 2012 | 06:36 PM
What can I do about it ? Should I get an after marker one if so what kind thanks
Old Nov 16, 2012 | 08:37 PM
Damon's Avatar
There are known issues with the factory tach. In particular, there is one resistor that often goes out on the circuit board and usually causes the problem. Do a search- it's been addressed before.
Old Nov 17, 2012 | 09:54 AM
lozantius82's Avatar
Car: 89 Camaro Iroc Z
Transmission: MK6 World Class T5
Axle/Gears: 9 bolt had 3.45's, now 3.27 gears
Your car is idling fine buddy, its your tach. Its way off, you need to go to the wrecking yard and find one that works properly. FYI replace your battery instead cause your car is cranking slow and its building up a lot of resistance within the starter motor and will create a lot of heat within. That will ruin a good starter easily, and no need to rev this engine to moon especially when its not loaded. good luck
Old Nov 17, 2012 | 06:20 PM
thank you all for your repliesssssssss
Old Mar 21, 2013 | 01:51 PM
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
my 91 has the same issue
so its the tach that's bad? have been going nuts looking for vac leaks.... I shouldn't be able to rev that freely up to and beyond redline?
xavier_pr84
how does your car drive? have you noticed the tach reading higher while driving too.
Ed1LE
Sep 30, 2018 09:14 AM
okfoz
Oct 13, 2015 02:19 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
