92 RS 5.0 Engine to Cold?
Old Oct 10, 2012 | 01:58 PM
mu33rto's Avatar
Car: 1992 RS
Engine: 305 5.0L V8 TBI
Since these cars are meant to operated hot does having the engine to cold mess up the ecu? If I don't turn on the fans the temp gets really hot almost hitting 260 mark. I turn on the fan before that happens. If I run the aux fan before I turn on the car it stays below the 1/4 mark. Or the colder the better?
Old Oct 10, 2012 | 04:24 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 92 RS 5.0 Engine to Cold?
The fan should turn on by itself at about 228* F, or when the A/C is running.
Is the fan relay still connected to the head temperature switch? It is located between cylinders 6 & 8 in the head.
It is best to run the stock 195* F thermostat. A colder one does cause issues. You could put a head temperature switch in that closes at a lower temperature.
RBob.
Old Oct 10, 2012 | 05:49 PM
DancesWithDeath's Avatar
Car: 1991 rs camaro
That's what my 91 rs 5.0 runs at. Hey. What's ur oil pressure idle? And cruising
Old Oct 11, 2012 | 12:38 AM
mu33rto's Avatar
Car: 1992 RS
I just bought the car and the PO had a switch that turns on the fan manually. Also fans turn on with headlights. Hopefully this weekend I will have time to solder and replace all the wire the PO sliced into. I think he used a butter knife to cut the wire...Plus duct tape.. I just got the car to turn on properly. I'll see if I can try to put every thing back to stock.
I took the above pic at a redlight after about 15 min drive. It shoots up to about the 60 mark when driving. I'm not to sure thats a good thing or bad. Next oil change going to go from 20w50 to a lighter oil. Hopefully it doesn't mess with the oil pressure.
Cleotiz
Jan 6, 2018 08:56 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
