Popular spark plug choice?
Old Nov 7, 2012 | 08:20 AM
ricklovin93's Avatar
Car: 1988 camaro base coupe
Engine: 305 LO3
Transmission: gm 700-r4
Winter has come so its tune up time, any suggestions on spark plugs? I was thinking the E3 but my father said he heard some bad things about those plugs. Anyone else have bad experience with E3?
Old Nov 7, 2012 | 10:32 AM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
Re: Popular spark plug choice?
I too was going to get some E3's but ive been a little skeptical about them, and a little pricey too....So in the end I went with the Accel shorty plugs, my car seems to like them and so do I. They run a little over $30 for a set of 8 at autozone.
Old Nov 7, 2012 | 11:40 AM
rsmith085's Avatar
Car: '88 Camaro
Engine: L03 TBI
Transmission: WC T-5
Axle/Gears: 7.625 10 bolt stock 3.08's
IMHO a spark plug is pretty much a spark plug as long as you get the correct one for your car. Now if your running nitrous or boost it's critical to get the correct heat range but for a stock motor what ever they spec for the replacement is fine. I'm running Denso platinum twin tip plugs because I got them on sale for 1.99 a plug. I do like platinum plugs because they'll last longer than copper ones. NGK V power is a good plug as well. All the ones with multiple electrodes are really just a marketing gimick and not worth the $5+ a plug price to pick up just a few hp.
Old Nov 7, 2012 | 11:51 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
E3's have been proven in a lab situation that they burn more faster and completely than competitor plugs, but I'm skeptical in a working motor situation. Then you have to consider the cost factor if they are worth it to you. I would just stick with a good quality plug and change them whenever you feel the need.
Old Nov 7, 2012 | 11:54 AM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
Transmission: Built 4L60E
Axle/Gears: 4th Gen 3.42s
I work at an automotive parts store and after the stories and whatnot that I've heard of the E3s I wouldn't put them in any vehicle motor. A weed-eater or lawnmower is a different story. I've always run the Accel Header Shorty plugs and all my motors run great with them. It makes it a little easier in a thirdgen as well!
Old Nov 7, 2012 | 01:08 PM
Engine: 305 LO3
Were ac delcos the oe spark plug? The car I believe has champions in it now
Old Nov 7, 2012 | 02:33 PM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
ac delco copper are oe, champions would be fine, autolites wold be fine, platinum, iridium, would in theory last a little longer and spark a little better as they aged but its really all in how much you wanna spend, the laws of physics tell me the e3's 3 electrode design wouldn't do much
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Jlanz55
Sep 9, 2015 09:09 AM
Gunsbee
Sep 7, 2015 07:10 PM
