VRFPR
Old Aug 5, 2013 | 10:32 PM
  #51
Binder's Avatar
Re: VRFPR
Originally Posted by RBob
Need to reduce the AE, that is what is making the engine go so rich.
RBob.
Thanks!... and that sounds easy enough but I've been reading up on the AE functions and something that is screwing me up is that in TP the map values are kpa while the dump file info seems to be in % I think. How would one convert these values?.... Also in TP the TPS threshold value is in less than one percent. Does this mean that an increase in TPS of less than one percent would enable AE? If that's the case it seems it would nearly always be in AE mode.?????
Am I trying to over think this? Should I just reduce the entire AE map PW and AE tps PW tables by like 20% across the board and trial and error it in?
I won't be back to a race track before this weekend to test the results.
Old Aug 6, 2013 | 07:21 AM
  #52
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: VRFPR
No conversion required, the values line up between the two.
If it is set to 1%, that is a delta over time. So slowly opening the throttle and that threshold won't be exceeded.
Reducing both AE PW tables by 20% is a start.
RBob.
thomas1976
Jun 19, 2016 10:58 AM
Ron_90
Dec 24, 2011 11:02 PM
thomas1976
Dec 8, 2010 11:05 PM
thomas1976
Oct 7, 2009 07:05 PM
classiccar
Aug 10, 2009 04:35 PM
