Weird issue with 454 throttle body.
Old Dec 8, 2012 | 07:15 PM
KurtAKX's Avatar
Car: Pontiac
Axle/Gears: 3.08 / Drums
I have a 454 TBI installed on my 350.
I currently have the throttle screw set far enough open that I have 0 IAC counts at 600 RPM.
When the engine is not running, the throttle shaft rotates silky smooth.
The pedal action is nice and smooth.
When the engine IS running, the throttle blades act like they are being "sucked shut"- grabbing the throttle lever on the side of the throttle body to give it a twist, it's like you have to initially twist pretty hard to overcome the vacuum. Once you twist the throttle that initial bit it moves easily- it's just cracking the throttle that's miserable.
It feels sticky at the pedal as it does by hand.
My engine is running 600 rpm and 30-32kPa-ish manifold pressure (LT1 takeout cam)
So far I've tried opening the throttle via the screw (thinking the TBI was just shutting too far and binding the butterflies in the bore) and I've also tried bumping my idle timing down several degrees with the hope that I'd make a little less idle vacuum and it'd be easier to overcome that initial tough spot.
Anyone else have this problem?
Anybody got any good ideas to get rid of that unpleasantness when you first open the throttle?
Old Dec 9, 2012 | 10:34 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Weird issue with 454 throttle body.
This is usually caused by the throttle shaft bores being worn. Bushing them is really the only solution. If the wear isn't too bad you can cheat and use some thin wall brass tubing such as that from a hobby store. Still need to drill out the bores a little, but it does work.
RBob.
Old Dec 10, 2012 | 03:27 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
What intake are you using right now?
Old Dec 10, 2012 | 05:36 PM
KurtAKX's Avatar
Car: Pontiac
I am using the overpriced GMPP TBI unit, machined out to 2". My TBI is the newer 454 style with the wide passages. Because the GM intake doesn't have a large enough footprint to seal off those passages, I have a Jegs 1" TBI spacer plate intended for the later 454 TBI. It seals my iac passages on the TB, and with no IAC passages in the spacer itself, it seals to the intake.
Old Dec 10, 2012 | 05:42 PM
KurtAKX's Avatar
Car: Pontiac
I also have the throttle linkage spaced up a little over 1" to account for the second gasket and spacer. I couldn't do that very easily at the back of the bracket, so I fabbed up a bracket off the rear face of the head out of 1/4" steel plate to rigidly mount the rear part of the bracket up 1" higher. My geometry measures within 2mm of stock in every dimension, so I don't think linkage is my issue, especially since I feel the stickiness in the throttle itself with the cables detached.
Old Dec 11, 2012 | 09:04 AM
dctrumpet's Avatar
Sounds like a potential vacuum leak at the shaft.
Old Dec 11, 2012 | 09:21 AM
KurtAKX's Avatar
Car: Pontiac
Vacuum leak at the throttle shaft results in sticky throttle shaft?
Old Dec 11, 2012 | 09:24 AM
dctrumpet's Avatar
If there is play/wiggle in the shaft this can cause a vacuum leak and that "play/wiggle" can cause a binding of the blades
Old Dec 11, 2012 | 09:29 AM
dctrumpet's Avatar
You're in Decatur? I'm in Jacksonville
Old Dec 12, 2012 | 04:37 PM
KurtAKX's Avatar
Car: Pontiac
If I bring my TBI over, can you re-bush it? I'd prefer not to do it on an exchange basis because I already have a truck-style 700R4 linkage welded to the 454 shaft.
Old Dec 15, 2012 | 11:45 AM
dctrumpet's Avatar
Yes, I can do that
Old Dec 15, 2012 | 11:46 AM
dctrumpet's Avatar
217-473-4998 give me a call!
Old Sep 28, 2016 | 12:04 PM
Tc2youngblood's Avatar
Can I call you I have some question about my 454 newer TBI
Old Sep 28, 2016 | 12:08 PM
dctrumpet's Avatar
I believe we have been emailing back and forth the past few days? Tyrone correct?
jhawkeye
May 25, 2022 06:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
Fast355
Dec 2, 2016 06:33 PM
justin57
Aug 20, 2015 07:05 PM
sreZ28
Aug 14, 2015 07:48 PM
