Stock TBI FPR diferrences
Old Mar 2, 2013 | 04:29 PM
maitlandtron's Avatar
Car: 1985 Z/28
Engine: L98 Carbed
Axle/Gears: 9 Bolt Posi 3.45
Alright so I am in the process of doing a carb to tbi swap. I have gathered most of my components but I am stuck on one thing. I have the 454 TBI body, but I am a little confused on the FPR. I was told that 94-94 BBC trucks have 30psi FPR's. Are these the ONLY application where this is true? I found alot of choices at the junkyard but I just don't which to use. I have a FPR from a 1995 G20 van w/ 5.7 does that have the 12psi FPR I need?
I crossed referenced some part numbers and it seems the parts all the same. So I'm guessing its the springs that are different.
Old Mar 2, 2013 | 08:27 PM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Re: Stock TBI FPR diferrences
Yup just the spring ... U can also modify the stock regulator to be adjustable by drilling out the spot weld
Old Mar 2, 2013 | 08:36 PM
Car: 1985 Z/28
Engine: L98 Carbed
Well i ended up getting the injector pod from the 94 454 suburban. But i got the top/fpr from a 95 g20 350 van. The fpr already has a screw underneath for adjustment.
Old Mar 2, 2013 | 09:56 PM
Car: 1991 firebird
Axle/Gears: 4.10
Cool.. U should b good to go .. Just use the lighter spring .. And keep the high preassure spring as well in case u need to up fP in the future .. What is ur setup if u don't mind me asking.. Is the L98 the TPi 350? .. And do u have equipment ready to tune the TBI ECM ?
Old Mar 2, 2013 | 10:09 PM
Car: 1985 Z/28
Engine: L98 Carbed
Its a stock L98 long block with a performer intake. Headers, 3" exhaust, no cat,, flow master. I have a world class t5 behind it. Like I mentioned earlier my throttle body is off a 454 and my injectors are the 65# ones. I'm in the process of ordering all the things I need to burn proms. Its a big project, but I think I can handle it.
Old Mar 2, 2013 | 10:11 PM
Car: 1985 Z/28
Engine: L98 Carbed
Oops, I didn't read your entire post. Yes the L98 is the tpi 350.
Old Mar 2, 2013 | 11:31 PM
Car: 1991 firebird
Axle/Gears: 4.10
Have u looked into EBL ? It's alot better than burning proms man .. I wouldn't waste my time with the old chip burning method .. EBL flash is about 400$
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
wayshegoes
Aug 17, 2015 12:00 PM
Randomtask2
Aug 13, 2015 01:57 AM
