1983 z28 tbi c/f injection
Old Mar 3, 2013 | 09:05 AM
loujon's Avatar
Get no fuel from either fuel injector. tank full. removed gas line from tank to fuel filter - cranked engine - no fuel flow. all fuses and relays are good. can anyone help. should fuel flow if i disconnect line to fuel filter and crank the engine?
Old Mar 3, 2013 | 10:49 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 1983 z28 tbi c/f injection
probably a bad pump or a bad connection cutting off power to the pump.if you hear the pump run but no fuel is delivered,the foam rubber coupler hose inside the fuel tank has likely turned to goo and blown out.
Old Mar 3, 2013 | 12:44 PM
kauboy's Avatar
Car: 83 Z28 Crossfire
Fuel pump should be activated for a couple seconds to prime the system when you turn the key on so you should see fuel flow with hose to filter disconnected.
Cleotiz
Jan 6, 2018 08:56 PM
toronto formula
Nov 10, 2015 06:17 AM
AilmentDiavolik
Interior Parts Wanted
Sep 9, 2015 02:17 AM
z28addict8490
Sep 5, 2015 03:56 PM
3tas4me
Sep 4, 2015 01:45 PM
