5.0 TBI question
Car: 1989 Camaro RS
Engine: 305 sbc
5.0 TBI question
So, i have a 5.0 tbi, bone stock. wanting to clean up the engine bay, make it look nice, decided to go with an open element air filter, but my problem is i have an MAF sensor attatched to the stock breather. any way i can take it off? what would happen if i did? or, is there anyway i can drill into the bottom of my open element air filter and attatch the MAF sensor to it, and if so, how? thanks
Car: 89 RS
Engine: Stock L03
Transmission: Stock T5
Axle/Gears: Stock, Too high
Re: 5.0 TBI question
That's the Intake Air Temp sensor, not MAF, your car uses MAP. What to do with the IAT is mentioned in the above sticky threads, you can either install it in the aftermarket cleaner base or tie it up somewhere in the engine bay, cooler generally better.
Car: 1989 Camaro RS
Engine: 305 sbc
Really? huh, had no clue. thanks man.
Car: 1989 Camaro RS
Engine: 305 sbc
What exactly is it connected to (other than the breather) and what affect on the car would there be if i removed it?
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
You can open up a TBI engine bay ALOT depending on how far you want to go. Check out my cardomain for the pics of what I did when my car was still tbi.
Iroc8t8
Aug 26, 2015 08:14 AM
