modified TBI body/port fuel inj intake combo
Car: '88 IROC T5 Vert ‘13 Vette
Engine: 305 TBI
Axle/Gears: 3:08
Has anyone here ever removed the injectors from a 305/350 or TBI to use it as a throttle body while using it on an Holley open plenum intake with cast-in injector bosses? (I forget the part no.)
Would this be an economical way to get more airflow if one could find a practical way to drive 8 fuel injectors?
Say, converting from an L03 to a mild 400 sbc and T5?
Thanks, maybe this should be in the alternative EFI forum.
Re: modified TBI body/port fuel inj intake combo
Yeah, edelbrock has a kit to convert your tbi system to efi. I'd don't know if anyone ever put it on a f body, it was marketed for trucks.
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
You should just get an aftermarket TBI intake , and get a nice custom chip made for your set up.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I'm doing this same thing for my LT based 383. I'm using the Hurricane manifold and a modified 454 tbi unit. I'll take pics of it tonight.
Engine: 305 TBI
Axle/Gears: 3:08
What computer are you using to drive the 8 injectors if so/
thanks
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
A 1227730 would do the trick
I'm going to be using the EBL Flash with the Port mod to run 8 injectors. Easy money lol
Are you certain the 7.4L TBI is adequate? i run one with inj pod and I am seeing 90 MAP. Elevation is 1000 feet. Key on is 96.....
From the calculations I did my engine only needs 683 cfm to turn 6500 rpms so it should be more than adequate for what I'm using it for. Plus I'm doing a "mild" port job to radius the bowls more for better flow so that should give me even more cfm.
Engine: 305 TBI
Axle/Gears: 3:08
robertfrank I'm going to be using the EBL Flash with the Port mod to run 8 injectors. Easy money lol
Does a Port Mod modify a TBI stock L03 computer, and would all that's necessary to do the above be cheaper than a installing an EZ EFI TBI or Atomic TBI EFI?
Yes, Rbob (who is a goddamn genius) can modify your stock computer. Check out www.dynamicefi.com . I think that you could possibly do this conversion far cheaper than the atomix or proflo setup if you play your cards right.
I have a few more that I can post later if needed.
Fast355
Dec 2, 2016 06:33 PM
92camaroJoe
Aug 13, 2015 06:07 AM
