TBI 220 leaking after overhaul...
Old Apr 27, 2013 | 02:13 PM
Jabpir8's Avatar
Car: Buick RMW 92
Engine: L05 5.7L V8
Transmission: 4L60
so ... got an ACDelco overhaul kit, new injectors and adjustable fuel pressure kit.
but, when I test the unit on the car it leaks throughthe TBI cover seal.
I torqued the 8 screws to 28 in-lbs as per manual.
Do I have to use RTV or equivalent on the seal ???
need help, don`t wanna set the car on fire.
Old Apr 27, 2013 | 02:22 PM
goliath88's Avatar
Car: 88 firebird convertible
Engine: 305 tbi v8
Re: TBI 220 leaking after overhaul...
you replaced the o rings that go around the screw holes?
Old Apr 27, 2013 | 02:32 PM
Jabpir8's Avatar
Car: Buick RMW 92
Engine: L05 5.7L V8
Transmission: 4L60
There are no oring around screw holes.
Orings are around injectors inside each pod.
Sealing is done thanks to one big seal with the shape of the upper and lover body parts.
Now I do not know how to seal this if the new seal is not doing the job.
Old Apr 27, 2013 | 11:43 PM
goliath88's Avatar
Engine: 305 tbi v8
I know they sell a thicker seal with some kits, there's two little "figure8" seals that go bad that create the leak you're talking bout also. Sorry if I'm no help man. I've disassembled mine a bunch of times and noticed those rings I'm talking about are the first to go. I can only suggest you sand the body and meter to make sure there's no high spots. After that a new seal should work with no sealant needed. Hope this helps you out brotha.
Bubbajones_ya
Jul 6, 2024 08:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
86IROC112
Sep 11, 2015 04:04 PM
92rsvortec350
Sep 10, 2015 10:54 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
