Rough idle, dies when put in gear
Old May 4, 2013 | 11:01 AM
djeremy75's Avatar
Hi guys, I have an auto 305 tbi 90 Camaro. I got it, it my first third, and it died not a month later. I recently got the fuel pump changed out after it sitting up for a few months. I managed to drive it home, but it died twice on the way there. Now here's what it's doing: it cranks fine if I give it throttle, but I have to keep it applied the whole time or it'll die quick. If I put it in drive or reverse, it'll die immediately if not given throttle. It's also blowing a lot of smoke out of the exhaust, when it's cold or warm.
I've replaced the fuel pump and fuel filter, it had proper oil, and I tested the alternator and it was fine. I was thinking fuel injectors and was wondering if anyone had a similar experience or had knowledge on this?
Old May 11, 2013 | 01:53 PM
two-if-by-sea's Avatar
Car: 89 RS Vert, 89 Formula, 89 Bird
Engine: L03, TBI 350, none
Transmission: 700R4, 700R4, none
Axle/Gears: 3.42, 3.45, none
Re: Rough idle, dies when put in gear
I had this exact problem last month. At traffic lights I had to shift into neutral to keep it revving. Distributor was replaced, and all is well now.
Old Jul 16, 2013 | 04:12 PM
zephyrinias's Avatar
Car: 1983 Trans Am
Engine: 5.0L Crossfire TBI
I had the same problem.
Remove and check/clean the idle air control valves with a quality mass airflow sensor cleaner spray. Make sure to scrape all the junk from the pintle valve.
Old Jul 17, 2013 | 12:15 AM
JohnneyR's Avatar
Car: 92 Camaro, 72 Chevelle
Engine: 305, 350
brb
Old Jul 17, 2013 | 07:05 AM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
I had the same issue and for me it was coolant temp sensor and timing was off.
Old Jul 17, 2013 | 07:13 AM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
My 90 camaro starts up, idles great for about 3 minutes and then gets really rough, shakes like its missing.
Getting ready to do egr valve, iac replacement, hoping this will help.
Sounds almost the same as what you are getting. I have heard the CTS contributes alot to this condition also. May do that as well ...
Old Jul 17, 2013 | 07:27 AM
rdhanded2's Avatar
Top Answer: 1
I went crazy trying to track down what was doing it. I replaced egr and iac both. Checked my injectors, fuel pump, fuel filter, everything. When the cts was changed it made a large difference, but was still surging some. The timing on top of cts cleared it all up. I was lucky enough to have Chevy8588 check it with me because I was pulling my hair out. He knew what it was right away and made me feel dumb! lol
Plus, if you are changing stuff you might as well swap it out also. I went with the "expensive" one and it was only $17. Cheap and worth it.
Old Jul 17, 2013 | 09:58 PM
Car: 90 Iroc Vert
Engine: 5.0L
$17 ... thats a no brainer.
Tearing off the TPI plenum as soon as the heat wave passes, too dam hot to work on it now.
Thanks - I will try it.
Old Aug 26, 2020 | 06:51 PM
mdharne's Avatar
Engine: 305 tpi fuel injected
What did you change for 17 dollars? I have a 1990 and have the same problem.
Old Aug 26, 2020 | 07:11 PM
rdhanded2's Avatar
Top Answer: 1
Coolant Temp Sensor
Old Aug 28, 2020 | 12:42 AM
Schurkey's Avatar
Originally Posted by rdhanded2
Coolant Temp Sensor
Seven years ago.
There's a dozen things that could be wrong. Connect a scan tool, read the data stream.
When this was me, it was the pickup coil in the distributor.
Shinobi'sZ
Feb 3, 2025 07:46 AM
servo2055chevy
Mar 25, 2013 10:36 PM
gatoRS92
Oct 18, 2006 02:38 PM
OUTATIME GTA
May 19, 2003 06:58 AM
Iceyntenn
Jan 5, 2003 04:27 PM
