Open Element Air Filter
Old May 6, 2013 | 10:51 AM
GilbySauce_24's Avatar
Car: 1992 Camaro RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
Hey guys, just signed up on here because I bought a 1992 Camaro RS this past saturday. Everything is stock now and only has 60,000 miles, but I want to put an open element on it. looked around here quite a bit and searched some threads, but a lot of things were said for different kinds of filters. This is the one I will most likey be getting. http://www.rickscamaros.com/camaro-air-cleaner-assembly-open-element-crinkle-black-finish-with-bowtie-and-chevrolet-word-1967-1992.html I Also read things about the "golden plate" that restricts almost half of the airflow into the carb. I am just looking for a complete list of what I need to do or other parts I need to get. Do I need to worry about the MAP system (air density) or MAS (mass airflow sensor) when taking off the stock intake? What about vaccum lines?
Old May 6, 2013 | 05:47 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: Open Element Air Filter
http://snflupigus.tripod.com/tech/op...tep1/step1.htm
Old May 6, 2013 | 07:47 PM
Car: 1992 Camaro RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
Perfect! Thanks!
Old May 14, 2013 | 09:22 AM
Jake_92RS's Avatar
Car: 1992 Camaro RS, 2012 Camaro SS 45th
Engine: L03 305 TBI V8, Blown 6.2L LS3
Transmission: 700R4, TR6060
Axle/Gears: GM 7.6" 10 Bolt 2.73
If you can rig that air cleaner to fit, let me know how you did. When I tried to put mine on, it rubbed the ignition coil wires, and if i raised it up any higher it touched the hood, and the parts like the thread adapter and bowtie wingnut didnt fit right on the stud. So please let me know if you find a way to fit it on there.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
wruiz
Aug 13, 2015 09:07 PM
