No acceleration
Old Jun 26, 2013 | 12:44 PM
Tandyman's Avatar
No acceleration
Hey Guys,
I have a 1992 Rs Camaro V8 305. It starts up great the first time but has no acceleration. Then when you stop giving it gas it stalls. It then is really hard to start again. You can press the gas as hard as you want and it doesn't go anywhere. Just zero acceleration. The engine seems to run hot too. The temp gauge shows its fine though. I replaced the fuel lines (they were rusty) the fuel pump and filter. The injectors are fine and the spark plug lines are fine too. What is wrong?
Old Jun 28, 2013 | 01:40 PM
Ronny's Avatar
Re: No acceleration
Is the spray conical? Maybe the filter is clogged again?
CE light?
I bet fuel related...
Old Jun 28, 2013 | 03:03 PM
Tandyman's Avatar
Re: No acceleration
The injector sprays are perfect. We replaced the fuel lines, fuel pump, and the fuel filter. The injector filters are fine too. The check engine light is on too
Old Jun 28, 2013 | 03:04 PM
Ronny's Avatar
Re: No acceleration
OK what are codes?
Old Jun 29, 2013 | 09:11 AM
Tandyman's Avatar
Re: No acceleration
Sorry I had to get em. THe codes are 23 and 33
Pac J
May 17, 2020 10:44 AM
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
ULTM8Z
Sep 16, 2015 09:15 AM
