lt1 what can i use on my lo3
Old Jul 22, 2013 | 06:55 AM
jdawg1276's Avatar
Car: 1988 camaro
lt1 can I uses the head and intake on it? I know the cam but is there anything else?
Old Jul 22, 2013 | 11:22 AM
Ronny's Avatar
Re: lt1 what can i use on my lo3
Some have converted the intake for sure. check out Corvette Forum with a search. As well as a recent thread.
Maybe some here have done same. Search.
Old Jul 22, 2013 | 03:31 PM
jdawg1276's Avatar
Car: 1988 camaro
I have all I come up with is cams
Old Jul 22, 2013 | 04:24 PM
Ronny's Avatar
A search came up with this
http://forums.corvetteforum.com/c4-t...e-miniram.html
http://forums.corvetteforum.com/c4-t...-my-setup.html
https://www.thirdgen.org/forums/alte...nversions.html
Old Jul 24, 2013 | 01:16 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
You can use the heads if you have them modified as well as the intake. The cam is a no brainer.
Old Aug 15, 2013 | 02:06 AM
88SS6SPEED's Avatar
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
You can all parts internal from the LT1, I.E., the entire valvetrain system, the rotating assembly, with the exception of the Pistons of course. The rotating assembly is stronger than your stock L03 setup. You will have to use your L03 harmonic balancer. You will also have to have the LT-1 crank and rods balanced with the 305 pistons, if you use them. You can also use the oilpan, and flexplate plate from the LT1, whether the flexplate is the (12-3/4"/153 tooth) version found on most F-BODY and Y-BODY LT1s, or a (14"/168 tooth) versions, found on the B-BODY LT1s. The flexplate choice is heavily dependent on whether your L03 block is machined for both STARTER sizes. If so, then the choice is yours . HTHs
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
anesthes
Sep 21, 2015 10:24 AM
L0tuS
Sep 4, 2015 11:16 PM
