VATS or Fuel Pump????
Old Sep 25, 2013 | 11:03 AM
wahoo's Avatar
Car: Camaro RS 1992
Engine: 305 TBI
Transmission: TH700R4
I have a problem for several months with my camaro...
The engine won't start, and I no fuel is arriving in the TBI
The stock pump is dead but still in the fuel tank. The previous owner put a new pump outside the fuel tank.
I don't hear the fuel pump when I switch on the car...
For me the new pump is dead too.
But my car is a 92 RS and can you tell me if it can be a VATS problem?
I read the trouble codes, and only 12 flashes.
Old Sep 25, 2013 | 01:23 PM
admathi's Avatar
Re: VATS or Fuel Pump????
If it was a VATS problem, your "security" light should come on and stay on (on your guage cluster). I would check your fuel pump relay and check the grounds for your fuel pump. Unfortunately, I don't know where that particular ground is on the TBI, but someone else might know on here. If your relay is good and the grounds are good, I'd replace to external pump.
If you want to bypass your VATS, there are several "VATS bypass" modules available on ebay for under $30; however, this doesn't sound like VATS to me. Here is a link, there are tons of vids on youtube about bypassing the VATS key.
It sounds like either the relay or the fuel pump need to be replaced. I had a similar problem on my 350 TPI, and it was the fuel pump relay. I also had a similar problem on my LS1 swap, I thought it was the VATS, but it was the fuel pump ground. Hope this helps.
Old Sep 27, 2013 | 06:39 PM
Schurkey's Avatar
The fuel pump relay is bypassed automatically by the oil pressure switch, if the engine is cranked long enough to build oil pressure. This assumes that the wiring harness including fuses is in good condition, and only the relay itself has failed. It also assumes that the fuel pump will operate if provided with power and ground.
Better to find out FOR SURE if you have fuel pressure by connecting a gauge in-line with the TBI. There is no service port for convenient access, so testing fuel pressure is unreasonably difficult due to GM cost-cutting.
Old Sep 27, 2013 | 11:27 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
It is not advised to suck fuel through a in-tank pump that is not working , can burn out the upstream pump
Old Sep 29, 2013 | 08:04 AM
wahoo's Avatar
Car: Camaro RS 1992
Engine: 305 TBI
Thanks for all your replies.
The switch on, there's no noise from the new fuel pump.
When i try to start the engine, i can see the securite light flashing. And when I stop to crank the engine, the vats light comes to off. There's no error code stored in the ECM. So for me the vats is OK.
Old Sep 29, 2013 | 09:24 AM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
some of the aftermarket pumps came with a inferior internal hose. i had to pull my tank because the hose burst.
Old Oct 4, 2013 | 02:45 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
VATs will not affect the fuel pump. I second what vetteoz said, probably the new fuel pump was over-burdened sucking through the original pump and burned itself out. Get a test light or multi meter and check that you're getting power at the pump both with the key on and also while cranking. If no power go back to the fuse and relay.
Old Oct 21, 2013 | 04:40 PM
wahoo's Avatar
Car: Camaro RS 1992
Engine: 305 TBI
For information, after testing, the external fuel pump is dead. RIP
Now I have to replace it only to move the car to his new home...
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Jae992
Aug 27, 2015 09:07 AM
92camaroJoe
Aug 13, 2015 06:07 AM
djmarch
Aug 9, 2015 05:27 PM
