92 rs injectors not firing
Old Oct 5, 2013 | 06:58 PM
bobs92RS's Avatar
ok so i replaced my feul pump after buying a car tht was parked due to dead feul pump ... dont have a pressure guage so i havent checked the pressure but i get feul to the front lines but not much ... and my injectors arent firing up ... also replaced my intank screen inline filter and relay...
not many resourses at my disposal and a VERY limited income NEED this fixed only vehicle left ...the daily driver was wrecked by girl friend
Old Oct 6, 2013 | 03:50 PM
Schurkey's Avatar
Re: 92 rs injectors not firing
Do you have spark?
No injector spray, no spark may mean defective distributor parts or defective wire harness between distributor and ECM, or a defective ECM. I'd be looking at distributor parts, first.
Spark but no injector spray may mean defective wire harness between injectors and ECM; popped fuse, or no fuel pressure.
Old Oct 6, 2013 | 05:03 PM
one92rs's Avatar
Car: SOLD!!!!!
what do you mean by not much fuel. it only runs at 9 to 11 psi.
Old Oct 6, 2013 | 06:06 PM
jdawg1276's Avatar
Car: 1988 camaro
I thought it was 9 to 13 was what they recomend?
Old Oct 7, 2013 | 02:09 PM
Ronny's Avatar
You can borrow a noid light at AZ. that will tell you if current to injs.
Old Oct 10, 2013 | 12:40 PM
bobs92RS's Avatar
will do that then didnt know they were on a loaner plan ...Thanks for the info
Old Oct 10, 2013 | 12:49 PM
bobs92RS's Avatar
and the car will run if u put gas down the throttle body ... so i know the motors good
Old Oct 10, 2013 | 02:52 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
If you did that then you know its got spark and is fuel related. I usually test that with starter fluid spray.
Check the injector fuse?
Check the car for codes and see if its throwing the dreaded code 54 fuel pump.
Check the fuel pump relay.
Lastly is there fuel in the tank? The gauges on these cars can get really off. Mine shows 1/4 tank when empty these days.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
sahlomonic
Sep 20, 2015 07:15 PM
webeeZ28
Sep 14, 2015 12:00 PM
92rsvortec350
Sep 10, 2015 10:54 AM
Ranbo108
Sep 9, 2015 12:20 PM
