Planning some minor engine changes...Need a little input...
Old Oct 27, 2013 | 11:58 AM
86FLIROC's Avatar
I am planning to change a few things on my 95 TBI 350. Not in a Camaro, but a 4X4 tahoe. Everyone on my other boards say to look here for the best advice on TBI out there.
I thought long and hard of the vortec heads, but I really don't wish to have to hunt down special manifolds or use tbi adapters. In the department of the head change, I am thinking L98 heads off a TPI 350. Keep in mind, I am looking for more power than the TBI heads can do, but I am not building a race car either...
Cam choice from what I hear is a cam from a LT1 engine. Yep roller cam. I am just hoping my block is able to be used for the cam. I also read the Melling MTC 1 is a good choice, and should work fine with the TPI heads.
I wanted to get a gear drive, but from what I understand, they don't like the knock sensor very much, so that idea may be dead.
I already have done the TBI mods, and have the Edelbrock 3704 manifold on it. Stock exhaust manifolds as well, but was thinking about shorty headers.
So, at least at this point it seems like lt1 cam, tpi heads, and put her all back together... Any suggestions if I am heading in the right direction?
Thanks in advance!
Shawn
Old Oct 27, 2013 | 07:15 PM
ex-x-fire's Avatar
Re: Planning some minor engine changes...Need a little input...
Corvette l98 heads don't have egr passages, they have the old bolt pattern & angles (tbi intakes have different center bolt angles), & they don't flow that well. Google the Hot Rod article "F Notes", they used some of those parts on a 305.
Old Oct 28, 2013 | 05:30 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I would use a better cam and after marked aluminum heads.
Old Oct 28, 2013 | 05:58 PM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Ditto !
colton_carlson
Mar 8, 2019 12:21 PM
Infested
May 22, 2018 11:56 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
