350 Conversion?
Old Jan 15, 2014 | 11:04 PM
Xephy's Avatar
Car: 1992 Camaro RS
Transmission: A4
350 Conversion?
I found a 350 TBI motor from a 1990 z28 and was curious if the motor is a straight drop into my 92 camaro rs 305? What changes do I need? The motor has 50K original miles and he wants $800 for the motor.
Old Jan 15, 2014 | 11:10 PM
Schurkey's Avatar
Re: 350 Conversion?
Engine drops right in. May have slightly-different sensors or molded connectors for wire ends.
Still need different tune parameters in the computer. (so maybe take the computer and wire harness from the '90) For $800, the guy should throw that stuff in with the engine.
Xephy's Avatar
Car: 1992 Camaro RS
Transmission: A4
Re: 350 Conversion?
How will my transmission hold up and stuff?
Old Jan 16, 2014 | 02:37 AM
Schurkey's Avatar
Re: 350 Conversion?
I expect you'll find the weak points eventually.
Old Jan 16, 2014 | 07:36 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 350 Conversion?
There is no such thing as a 350 TBI from a '90 Z28. GM never put TBI 350's into f-body's.
Better check that engine carefully before purchasing to know exactly what you are buying.
RBob.
Old Jan 16, 2014 | 07:59 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: 350 Conversion?
Old Jan 16, 2014 | 10:40 AM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Re: 350 Conversion?
Need bigger injectors, a few different sensors, a tune.
But, as I asked in one of your 12 other threads in the past 2 weeks, did you ever figure out the starting issue before you go swapping engines? Hopefully you'll read the advice in this thread before you change your mind and go jumping off to another thread again...
buffaloman
Firebirds Wanted
Sep 7, 2015 09:47 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
Billy Decker
Sep 4, 2015 03:46 PM
85Special
Sep 3, 2015 04:21 PM
Formula_88AE
Sep 3, 2015 01:47 PM
