help no spark
Old Jan 23, 2014 | 10:48 AM
fattz's Avatar
Car: 1991 camaro rs
Engine: 5.7
Axle/Gears: 2.77
help no spark
Ok I have read other post just start off, but need fresh ideas. I have a 91 rs with a 5.7 tbi swap. To start, distributor is new, msd coil, wires, plugs, c,aprice chip, have injector pulse during crank, changed module with spare, have voltge to coil, grounds all check out, new knock mod. Using same knock sensor, bought new can't findx it. Have volage on trigger wht/tan. ??????????? Any other ideas
Old Jan 23, 2014 | 10:54 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: help no spark
Have you had the module and coil tested? Not unheard of any more for new parts to fail.
Old Jan 23, 2014 | 02:16 PM
fattz's Avatar
Car: 1991 camaro rs
Engine: 5.7
Axle/Gears: 2.77
Re: help no spark
I switch the module with another one and I'm starting to think that the MSD coil I bought is bad
Old Jan 23, 2014 | 02:55 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: help no spark
Good possibility. Since the injectors fire during cranking, that means that the distributor is sending reference pulses (DRPs) to the ECM. These DRPs originate from the pickup coil and are buffered by the ICM. The ICM then sends the DRPs on to the ECM.
The ICM should also be charging the coil and firing a spark plug on each DRP.
RBob.
Old Jan 23, 2014 | 04:22 PM
Schurkey's Avatar
Re: help no spark
MSD coils are mostly made in China; the OEM coils are all you need and much less expensive.
Might want to look at the second section of this article:
http://www.chevelles.com/techref/ftecref5.html
Old Jan 24, 2014 | 09:57 AM
fattz's Avatar
Car: 1991 camaro rs
Engine: 5.7
Axle/Gears: 2.77
Re: help no spark
Ok new coil, another module, checked ground s, tried 5.0 chip, bad ECM? TRYED pinning it out last night to see of had any signal on signal wires with a old bulb type test light did not see anything while cranking not sure I did it right, going to check for contunoty in signal wires now. But any ideas?
Bad Ecm?
Old Jan 24, 2014 | 11:10 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: help no spark
Bad Ecm?
Unlikely. Unplug the 4-wire connector from the distributor. This takes the ECM completely out of the equation. Note that the injectors won't fire, which is good as they won't flood the engine.
But the spark plugs should still fire. So can continue to troubleshoot. Note that the knock system has nothing to do with the lack of spark.
RBob.
Old Jan 24, 2014 | 03:57 PM
fattz's Avatar
Car: 1991 camaro rs
Engine: 5.7
Axle/Gears: 2.77
Re: help no spark
That did not do anything, the ECM sends the signal to open and close IcM to create a ground to create spark. I probed out the harness and have continuity. Last possible thing is a circuit in ECM
is burnt. Any last ideas. Because thenly thing that is old is that
Old Jan 25, 2014 | 10:09 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: help no spark
Not until the engine is above 400 RPM does the ECM control timing. Until then the distributor fires the spark plugs at the base setting. Same as having the EST/BYPASS connector open.
The two wire pigtail between the ICM & coil may be bad.
RBob.
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
