LO3 To L30 Vortec Swap: Completed(Mostly)
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
Re: LO3 To L30 Vortec Swap: Completed(Mostly)
As noted in my above post, the DC under WOT was hitting above 80 a few times. Kicked the log to RF who made the decision that we need more injector.
Took a nice road trip to RFMaster's warehouse (garage) yesterday, dropped of the cherry picker, and picked up a new 62lb @17psi injector pod he had on the library shelf.
Those should provide enough fuel for this beast.
RF adjusted the bin for the new injectors and I've been running ve learns since installing them. Looks mostly rich in most areas which is expected. Screenshot below.
Also took the car to an exhaust shop, had them cut the ypipe and bend a new section for the driver collector as it was slightly off and leaking. Then found a leak at both header gaskets which turned out to be loose bolts! They were all about 2 turns loose! One bolt actually backed all the way out and is missing. Bought a replacement from Oreilly. Shop also made a new hanger for the transmission/cat. This should fix the dragging issue I had whenever I would go over anything.
Running good! Special thanks to RF for his continued support and putting his warehouse up for use!
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Yes, just continue with VE learns and later ease into AE tuning. Be on the lookout for bogs - a lot more fuel being dumped at once so that TPS AE and MAP AE tables may require manual tuning.
//RF
Car: 1983 G20 Chevy
Transmission: 4L60
Excuse my noobness, where in the log do I view how much it is retarded?
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Axle/Gears: Stock
Ran the car again tonight with a datalog. The actual Driving was fine and it ran with power. Problem is at idle it was running rough in closed loop. Did some idle ve learns and every time of about 6 times it kept pulling fuel out at idle but didn't fix the idle.
Remember we have 70pph injectors on it now.
In open loop it idles fine but as soon as it hits closed it starts running rough. Also I noticed that the PW at idle was around 1.1 with SA bouncing between 14-18. Any ideas? DC at WOT- never got above about 62 so we have plenty now at wot. Log attached. You guys can see the idle towards the end.
Axle/Gears: Stock
More tuning going on here. Injectors are flowing too much fuel to the engine at idle causing rough idle in closed loop. Will force open loop at idle to address since it seems to idle nice in open.
Did some more driving today and came up with reduced knock. On the first WOT run I had no knock, second popped up some. Better than before though. Fast355 I've attached the spark retard and knock counts. What you think about them? This was done in clear weather at 93* F ambient temp.
Any objections to forcing open loop at idle?
Knock
Spark Retard
Knock
Spark Retard
Car: 1983 G20 Chevy
Transmission: 4L60
Spark looks fine. Probably need to reduce the proportional duration to lessen the fuel injected as the 02 sensor falls lean. I would think you could still run closed loop idle.
Car: 75 Beast
We did this in the current BIN to account for pressure increase from 12 to 17 PSI. After reviewing logs it looks like it is idling just fine CL.
//RF
Axle/Gears: Stock
Car: 1990 Camaro RS
Engine: L31
Your car is like the opposite of mine, blue vs red, 305 vs 350, chrome irocs vs my satin, blue underlighting vs my red, lol.
Axle/Gears: Stock
Axle/Gears: Stock
Axle/Gears: Stock
Car: 1990 Camaro RS
Engine: L31
The car came with 16s, the 18s are +2'd. I didn't have to do anything for the speedometer at all. 17s probably ride a whole world better.
Axle/Gears: Stock
The CS144 alternator blew last night on a part throttle pull. Its been cutting out the past few weeks. Possibly damaged it when the accessory bracket broke.
Let it cool overnight and still wouldn't charge today. Sent it back to rockauto and they are shipping the replacement.
Axle/Gears: Stock
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 75 Beast
AD-244 has upgraded electronics, but upgraded electrical parts can be retrofitted in to CS144. For example:
Bridge rectifier (late style case): DR5179PF with avalanche diodes 6x 60AMP diodes.
Voltage regulator - multiple choices are available depending on application
D445XHD - Voltage Regulator 12 Volt, P-L-F-S Terminals, 14.7 Voltage set point, 10 second delay.
D411XHD - HD Voltage Regulator 12 Volt, B-Circuit, P-L-I-S Terminals, 14.7 Volt set point, 2.5 sec.
capacitor - 461104 - Capacitor
In most cases stator and rotor are good to go. Check rotor for bad solder joints and slip traces for excess scoring.
AD-244
Rectifier -> DR4401HD - Bridge Rectifier Early Design w/ Heavy Duty 50 amp Diodes
T25XHD - Bridge Rectifier 70A press-fit avalanche diodes (good for 210 Amp).
Rectifier diodes alone do not determine alternator output capability. AD-244 was specifically designed to operated at lower RPM's. To accomplish this both stator and rotor windings were designed to generate higher magnetic field at lower RPMs. But that's another discussion all together.
The problem commonly faced with AD-244 swaps has to do DE-frame ears located 90 deg apart vs conventional 180 deg shared by 10DN/10SI/12SI/CS130/CS144
For a late third gen (aluminum driver side bracket) - the AD-244 might be a ticket - I simply do not have one laying around on shelf to try it out...
//RF
AD-244
//RF
Car: 1983 G20 Chevy
Transmission: 4L60
AD-244
//RF
AD-244
//RF
Car: 75 Beast
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 75 Beast
Fast
That's on the passenger side of G20 van using stock mount locations??
//RF
//RF
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 1983 G20 Chevy
Transmission: 4L60
I am not going to sacrifice cooling, A/C or electronic acessories to do that. The Tahoe fans move so much air I stay under 190*F in 105*F weather with the a/c blowing 38-40*F while towing the boat on the way to the lake. Fans alone are 40amps at idle.
Axle/Gears: Stock
The car is fine down the highway with AC full blast at 37* since i replaced the air dam. But in traffic when its only fan, it slowly creeps to 220. Like I said SLOWLY but still I would like to see 180 in traffic.
Fast are you positive the LS1 dual fans will fit in the Camaro? And are you sure they pull more than the taurus?
Car: 1983 G20 Chevy
Transmission: 4L60
Mine does actually pretty well. The biggest draw is the taurus fan. Didnt you recommend LS1 dual fans?
Really want to see it on a stock LO3 bracket
My thoughts exactly, now that I have the CS144 it keeps the fan supplied nicely. The CS130 couldnt. Problem i face now is not enough fan to keep up with my new AC and new motor. Worked good with the LO3 but not so much with this beastly L30 and the added power haha.
I will have to remember to take a picture of the alternator someday soon when I have the car unburied in my garage.
Your cooling issue is not the radiator or the added power, it is that extra bypass you have installed that is recirculating 210*F water right back into the cool water and a very quick rate.
Axle/Gears: Stock
LS1 fans work with on a 3rd gen, but require some modification for mounting. It has been done before and the posts are in the cooling system area.
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Car: 1990 Camaro RS
Engine: L31
The water pump to intake bypass. Vortec heads lack the provision for it that is normally found in all sbc heads.
Car: 75 Beast
Axle/Gears: Stock
My only concern is does it flow from the heads as well? If it does, then lets do it. The fitting at the intake manifold is seeping coolant anyway.
Car: 1983 G20 Chevy
Transmission: 4L60
Seems like a risky experiment RF. Although he is right in the sense that when the heater core is routed correct, there is a constant bypass there. Which it is now correctly routed.
It has been forever since I have looked at the rear water passageways on a Vortec TBI intake, but a production TBI intake manifold has a water passageway on each of its 4 corners.
Axle/Gears: Stock
If it worries you, when you block off the bypass for test purposes, drill a couple of small holes in a thermostat. The holes will allow for more bypass water warming up, but not prohibit proper cooling when hot.
Axle/Gears: Stock
CAR IS BACK ON THE ROAD!
Picked up the alternator from fedex today and got the alternator installed tonight after shaving the casing slightly to fit the caprice bracket.
After test driving the new alternator for about 15 miles, I couldn't get it to intermittently cut out like the old one did when at WOT or around 3000-3500. Seems the old alternator was just slowly dying.
I also captured the rough Idle in the log titled as such. Pulse width was at 1.1 when idling rough. I notice if I kick the fan on and put that electrical load on the motor, idle smooths.
Log below for you to check out Fast355.
Also RF, Fast, any suggestions for plugs to plug the bypass and test Fast's theory?
Small tidbit. RBob has some good stuff coming for us EBL guys! That man is a genius!
Car: 1990 Camaro RS
Engine: L31
For plugs you can get rubber caps from the parts store that you can hose clamp on.
What is the EBL spoiler?
Axle/Gears: Stock
Axle/Gears: Stock
Car: 75 Beast
RS
Take a photo of a bypass hose arrangement - picture is worth a thousand words.....
IRC intake uses 3/8" NPT and water pump 1/2" NPT plugs.
//RF
Car: check
Engine: check
Transmission: check
Changed that IAT SA compensation table to be able to use either the IAT/CTS blended value, or just the IAT value. Prior it was always the IAT/CTS blended value.
Selecting just use the IAT (option flag) is helpful when the knock is incoming air temperature sensitive.
Also, we are now putting updates on our web site. So can grab them when they are released.
RBob.
RBob.
Axle/Gears: Stock
RBob.
Axle/Gears: Stock
The bypass at the WP that GM told us to run is simply taking already hot water, and dumping it back into the water pump inlet and heating that water back up before it even hits the block. No cooling point in between.
The heater core bypass does essentially the same thing, but hits the radiator and cools back down before entering the block.
With that in mind, I'll be plugging the bypass on my next off day and seeing how it works. Any predictions on the effects on cooling?
Moral of the story, take a second to ponder on mechanical things before decisions.
Car: 1983 G20 Chevy
Transmission: 4L60
So fast, myself and RF took a minute today to actually think about how the bypass is functioning. Now it makes sense.
Axle/Gears: Stock
I see, so I'm nearly running all hot water then. Think plugging the second bypass will cool her down?
