305 TBI to 350 Vortec L31 Swap, it runs!
Car: 1990 Camaro RS
Engine: L31
Re: 305 TBI to 350 Vortec L31 Swap, it runs!
Thanks, I think I figured it out. In cmd I navigated to the directory with the s19_pat_.exe, bin and the patch in it. As I understand the tutorial I imputed s19_pat_ code43.s19 0x0000 mybinname.bin.
After I do that the cmd prompt just tells me copyright info, did it work? Tunerpro did update the checksum.
Car: check
Engine: check
Transmission: check
The offset is incorrect, use:
s19_pat_ code43.s19 0xD000 mybinname.bin
Note the leading 'D'.
With nothing but the copyright notice the patch utility ran OK. Meaning the it found the required files.
RBob.
RBob.
Car: 1990 Camaro RS
Engine: L31
Thanks again RBob. For my own education, how do you figure where to put the offset? I was following the patching guide and it said if the offset is included in the patch to use 0000. I will be sure to repatch the bin again using a virgin bin with my current tune after work.
On another note I tried out the timing map RS is using in his thread, increased my injector offset to 150 (I worked the math included in the mask) and increases my AE some more. I had no stumble or pop on the way to work. I will try to post up my current tune and log when I get home.
I truly feel the tune is coming together with the great help I have been getting.
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
On another note I tried out the timing map RS is using in his thread increased my injector offset to 150 (I worked the math included in the mask) and increases my AE some more. I had no stumble or pop on the way to work. I will try to post up my current tune and log when I get home.
Car: 1990 Camaro RS
Engine: L31
Okay, I took two bins with me to work. I had the one I thought I had patched in there on the way and an identical one but with no patch in a bag. After work I swapped in the unpatched bin. The popping came back but not as bad. I am wondering if the popping is the ECM trying to force a knock and advancing the timing too much. I have patched a new bin using the offset provided by RBob.
Some images of my log and tune
Car: 1990 Camaro RS
Engine: L31
Drove to work on the patched bin, it ran awesome. The popping must have been the forced knock advancing the timing too far. I don't know what could have been done without the patch. You're a smart fellow RBob.
Axle/Gears: Stock
How's that timing table running for you? Depending on which one you got, it made my motor knock.
Car: 1990 Camaro RS
Engine: L31
I used the last one you posted but I used the 3d view to put the timing back in you had taken out. I still haven't had time to get the y-pipe off the subframe connector so I believe I have phantom knocks.
Here are my knock counts and timing table if interested.
Axle/Gears: Stock
Man that looks like a look. Get that exhaust issue fixed. Then we will see how much of it is real
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Spaceboy
You should not be getting any 'real' knock around idle. High KS counts are likely due to mechanical rattling or exhaust system resonances. It is does not take much to trigger KS. I've also noticed rich condition around idle - you may want to trim VE table values in the 800 to 1200 RPM range by 40 to 50 kPA. This will move BLM counts away from 108 and give ECM some fuel adjustment room.
//RF
//RF
Car: 1990 Camaro RS
Engine: L31
Ya, almost all of my knock counts are around idle. I need to quit working seven days a week so I can relocate the arm on my UMI subframe connectors. I have hooked up my VRFPR to vacuum, I will log that and see if it helps my low rpm blms.
Should I be smoothing the tables after I adjust them?
Thanks for the advice and help gentlemen!
Car: 75 Beast
I would get BLM in the ballpark range first (128 +/-3 count) after that I would try to smooth VE tables. After smoothing - back out and collect more data. It is back and forth until you do not see further corrections greater 2 points.
//RF
//RF
Car: 1990 Camaro RS
Engine: L31
I hooked up the VRFPR to vacuum and got a bog. I think I am going to unhook it and cap it.
I still have my egr solenoid plugged in but capped off. If I unplug and remove it completely, will it cause problems with the computer? If it can be removed, can I remove the harness off of the coil for it also?
Car: 1983 G20 Chevy
Transmission: 4L60
Spaceboy
//RF
//RF
Car: 1990 Camaro RS
Engine: L31
I have developed some issues, I think my O2 may be lying to me.
I took fuel out in the table and my BLMs are unchanged. I took 30% out in the 800-1200 areas and 25% in the 1600-1800 areas in the area of use. I am still getting 108 and 128 blms at idle but it is usually hitting 108. Shouldn't I have some inbetween readings? It quite literally is either 128 or 108.
My 1600 up areas have now started hitting 133. I have seen some change there and need to fatten it back up a bit.
My idle has developed a slight stall in it. It never does stall but it loses about 200-300 rpms then recovers. When it does this my O2 reading drops way down to around 90. Why would my O2 fall out like that, could it be an intermittent open in the connection? It for the most part has a pattern to it but sometimes it goes longer between stall attempts than others.
The engine has also developed a lurch around 1100 rpms. It does it if you are barely on the gas, most noticeable trolling around a parking lot but it does do it at speed also if you hit the sweet (or should it be sour) spot. I am going to try my last bin before the current one and see if any of the stall/lurching abates.
Any wisdom from the crowd? I am going to continue to research these issues.
ETA: I have checked for vacuum leaks with propane and did not find any.
Car: 75 Beast
Spaceboy
To dig into this you should post a ZIP or RAR compressed file containing: Datalog, BIN file, and ADX used by TunerPro.
//RF
//RF
Car: 1990 Camaro RS
Engine: L31
Here she be, P9.bin is the most recent but I included the one before it. I was labeling it V1, etc but once I patched the bin I wanted a way to tell at what point it was done thus the P8, etc. I included the bin I was running before P9 also but the included logs are from the same day off of the P9 bin.
ETA:
Would help if I included the zip, lol
ETA:
Car: 1990 Camaro RS
Engine: L31
So I went back to my previous bin and the lurching seems better but it is still there. It is just off of idle and cruising at right around 1000 rpms. I am not convinced it is in the tune, I think something related to tbi may have failed. Could it be the tps going out? It reads fine in tunerpro.
Axle/Gears: Stock
Car: check
Engine: check
Transmission: check
The proportional gains one can be tested by forcing open loop all of the time (CTS threshold). Then seeing is the issue went away.
RBob.
Car: 1990 Camaro RS
Engine: L31
I will try that out when I am freed up. Kids restarting school and all has me hammered!
Car: 92 Camaro RS Heritage Edition PoloG
Engine: L31 Vortec
Transmission: 4160e
Axle/Gears: 4th Gen Torsion Rear/ 3.42s
Sweeet
Car: 1990 Camaro RS
Engine: L31
I got a new toy in the mail today so I will more than likely be continuing this thread in another sub forum. Since Fast liked the inclusion in the pic of the Z28 I added a couple more for him:
RBob, I will be contacting you once I have most of the parts gathered. This will be EBL'd.
Axle/Gears: Stock
Glad to see you join the EBL club though.
Car: 1990 Camaro RS
Engine: L31
Axle/Gears: Stock
Car: 75 Beast
RS not exactly - it does look like powder coated Holley Stealth Ram. Unlike GM TPI runner based induction system this does not use runners, but instead relies on large volume plenum for equalized air distribution. Can't use it here since it does not have provisions for EGR and was never certified by ECO-***** in the past.
//RF
Car: 1990 Camaro RS
Engine: L31
//RF
//RF
Axle/Gears: Stock
Yep, it is a HSR. I actually had some 24lb injectors already and have also sourced a SD ECM and a early throttle body. I plan to repin my harness using the guide and send the ECM out for EBL. I need fuel rails, I plan to use the seventy dollar pro comp rails, and some AN fittings and braided line to hook it all up.
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
Car: 1990 Camaro RS
Engine: L31
I got the HSR because it was on Holly's scratch and dent sale 100 off. It has stains on the base and I was painting it anyway so yeah 300 for a HSR.
Engine: forged 350
Ok thanks and yeah cant beat that.
Car: check
Engine: check
Transmission: check
About the ECM, if you are going with the EBL Flash w/Port Mod, don't re-pin anything. Only changes will be the TPS & IAC connectors (possibly), along with adding/changing to port style injector connectors.
The '90 - '92 SD ECM ('7730) is a different animal then the EBL Flash ECM system. Using it requires a total re-pin of the ECM harness connectors along with adding a third connector.
In this case you would need to use the EBL P4 Flash system.
Then: TBI versus MPFI, neither the EBL Flash w/Port Mod or the EBL P4 Flash system will run a TBI set up.
So need to have everything lined up to do this swap.
RBob.
Car: 1983 G20 Chevy
Transmission: 4L60
That HSR is going to look good under the hood.
RBob.
RBob.
Car: check
Engine: check
Transmission: check
Yes, you can run MPFI with an EBL Flash (or Classic) and no Port Mod. But it isn't ideal, a lot gets lost doing it that way. Also need to use injectors of 14 ohms or higher (on an 8-cyl engine).
We've had folks purchase an EBL Flash w/Port Mod and trying to stay TBI. So wanted to outline that a true MPFI ECM won't run a GM or Holley TBI set up.
RBob.
RBob.
Car: 1990 Camaro RS
Engine: L31
Wow RBob, that's even simpler than I thought. What is the base ECM of the port mod? My injectors check out at 16.4-16.5 ohms. I may send them to witchhunter before I put it together.
Car: 1983 G20 Chevy
Transmission: 4L60
RBob.
RBob.
Alot gets lost with batchfire, single bank fuel control, and lack of full time wideband 02 feedback as well. The Ultimate EFI fuel/timing control for a Gen1 small block IMO is the 24x/58x setup with coil near plug and a LSx PCM running it using a 4-7 swap cam.
I was running stock LT4 injectors, I believe they were in the 14-16 ohm range.
Car: check
Engine: check
Transmission: check
Multec's, used? I'd be leery if so.
RBob.
Car: check
Engine: check
Transmission: check
I understand where you are coming from. For someone not familiar with how EFI works, I could see the confusion.
As for the LSx PCM set ups, they do run well.
RBob.
Car: 1990 Camaro RS
Engine: L31
I am going to be on vacation out of town next week so I will probably order the ebl when I get back. Would it be possible for you to configure me a PayPal invoice? I think I will just purchase a full ECM out right.
Car: check
Engine: check
Transmission: check
Bosch is good. We can send a PP invoice, just need your PP email ID. And of course what you want to purchase. Don't forget a good USB to Serial adapter cable, the EBL Flash systems use a serial port.
RBob.
RBob.
Car: 1990 Camaro RS
Engine: L31
PM sent.
Does the cable stay on the ebl and ran to an accessable location? What ecm works best, 8746 or 7747 or are they both plug and play in my car?
Car: 75 Beast
Either 8746 or 7747 ECM can be used with EBL - my preference is for 8746 or later service replacement AC-Delco units.
Axle/Gears: Stock
Space out of curiosity, are you running a coolant bypass like I am? If so, go read my thread. Just had a epiphany haha.
Car: 1990 Camaro RS
Engine: L31
There are a number of items that may be causing it. The injectors may be switching in and out of async mode. The closed loop proportional gains may not be correct. Or the injector bias is to low causing the injectors to stop delivering fuel.
RBob.
RBob.
How can the injectors be check for sync and async mode switching? I would like to cure the surging if I can if it is in the tune.
Thanks!
Car: 1990 Camaro RS
Engine: L31
Well I started a new thread in alternative port efi if anyone wants to keep following:
https://www.thirdgen.org/forums/alte...ml#post5814337
I also found out in my CSM that GM calls the condition I am experiencing "Chuggle."
So did you finish the car? I've been reading through all the vortec swaps. Lots of good info.
84z96L31vortec
Aug 20, 2017 12:16 AM
