454 TBI questions
Old May 4, 2014 | 12:49 PM
MustangBeater20's Avatar
Car: 1991 Camaro RS
Engine: Built TBI 350
Axle/Gears: 3.42 Posi
454 TBI questions
I'm planning to rebuild a 350 with Vortec heads. However, I want to keep it TBI. The factory throttle body isn't large enough. So I was thinking about buying a 454 throttle body for it. Would it work? I know I would need to bore out the manifold to 2 inches. Is there anything else to worry about?
Old May 4, 2014 | 02:04 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: 454 TBI questions
Ideally the bores of the intake manifold must at least match the ones of the TB.
TGO member dctrumpet should have everything you need to switch over to the 454 TB, on he's ebay store.
Old May 6, 2014 | 06:19 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Match the injectors to the build. 454 injectors are likely too big.
You'll need a custom tune for new tb as well.
Old May 7, 2014 | 04:02 PM
Ronny's Avatar
I have run a 7.4L TB with 75 lb injs on my 350 for years.
If fact I just bought all needed to go to port fuel. I will hav the holley projection manifold, TB, and injectors for sale soon. Just need to find a few $$$ to replace what I stole out of my savings/retirement account
Old May 7, 2014 | 04:32 PM
Car: 1971 Camaro
Engine: 427
^ what's your specs? I'm guessing it's not a stock 350?
Old May 7, 2014 | 04:37 PM
Ronny's Avatar
edelbrock rpm late edition 64 cc alum heads, crane roller rockers 224/230 @.05 114 LSA
100 HP shot N20 hedman 1 5/8 headers real duals 2.25 hooker aerochambers Innovate WB EBL-ECU
Old Jun 1, 2014 | 01:06 PM
Car: 1991 Camaro RS
Where do I get a tune?
Old Jun 1, 2014 | 01:17 PM
Car: 1991 Camaro RS
Where did you get your tbi tuned?
Old Jun 1, 2014 | 01:42 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Like most of us we tune them ourself.
Old Jun 1, 2014 | 04:17 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Like i said in your other thread, check out http://www.dynamicefi.com/
Old Jun 1, 2014 | 06:49 PM
Car: 1991 Camaro RS
Wow... I'll highly consider this. What kind of throttle body do you use?
Old Jun 1, 2014 | 06:56 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I usually run Marine throttle bodies I have adapted over. They have 2" bore late model 454 style castings and 30 psi regulators.
MustangBeater20
Oct 29, 2022 09:20 PM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
