Code 36 issue
Old Jul 29, 2014 | 12:55 PM
Wesotsuki's Avatar
Car: 89' Iroc Z
Engine: LB9
Transmission: 5 speed manual - warner gear
Code 36 issue
So i got a code 36.
When i look it up on chilton/alldata it explains the issue is "ignition control 24x signal circuit error". Now when i cant wrap my head around is why the forums say its a "Burn off at mass air flow sensor OR Problem in transmission shift OR Fault in direct ignition system OR Missing pulses in electronic spark timing signal"
Anyways moral of the issue is, driving, engine warmed up, stalls/dies out.
Crank sensor or fitting is faulty or lose? Not entirely sure, maybe faulty ICM, ignition coil?
Any help, advice, knowledge is greatly appreciated.
Old Jul 30, 2014 | 07:45 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Code 36 issue
If this is the car in your mini-sig ('89 LB9), it is a MAF burn off relay malfunction.
Note that this is the TBI section, not the TPI section. An LB9 is a TPI set up.
RBob.
Old Jul 30, 2014 | 10:33 AM
Wesotsuki's Avatar
Car: 89' Iroc Z
Engine: LB9
Re: Code 36 issue
Oh wow I must be becoming illiterate. Or just really tired..could of sworn I posted in the TPI section. Thanks, much appreciated.
Old Jul 30, 2014 | 01:16 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Code 36 issue
Probably tired, I've done the same when responding to fuel pressure thread on the TPI board. Thought it was the TBI board and posted the wrong info. Did correct it the next day when I saw it...
RBob.
Cornholio7979
Sep 20, 2018 02:31 AM
777Shock777
Oct 29, 2015 04:30 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
mizz0313
Aug 12, 2015 06:45 AM
