L03 and headers / manifolds
Old Aug 24, 2014 | 04:35 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Due the swirl ports head on my L03 require any special consideration (port shape or location) when shopping for headers, or better flowing manifolds?
Old Aug 24, 2014 | 04:58 PM
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
No. Go with the Hooker 2055 if you need air tubes, if not go with the 2460's like me. And fork the extra money for ceramic coating. I should have.
Old Aug 24, 2014 | 05:27 PM
DynoDave43's Avatar
Re: L03 and headers / manifolds
Good to know. Std. SBC port configuration / shape.
There is a set of used LT1 shorties for sale locally. Has a very D shaped pipe / port. Is this also the "Std." shape, or was this special fro the LT series of engines?
Old Aug 24, 2014 | 06:46 PM
Axle/Gears: Stock
I would go for thirdgen specific headers. Anything else and you may run into fitment issues.
Also plan on picking up a LT1 starter for the heat soak issue you'll begin to have, and some new 90* plug wires
Old Aug 28, 2014 | 10:47 AM
skip91's Avatar
Car: '91 RS, '64 C10 Stepside
Engine: 305 TBI, '00 5.3
Transmission: Manual, Automatic
Axle/Gears: 4th Gen with 3.42, 4.10
I would assume Hooker has a matched Y-Pipe to work with these headers?
Old Aug 28, 2014 | 10:53 AM
hectre13's Avatar
Car: 1984 15th Anv. T/A
Engine: HO 5.0
Transmission: TH700r4
Axle/Gears: not sure yet!
personally, I would try and find a set of used headers cheap that are in decent condition and send them off to be professionally ceramic coated, like jet hot, because I bought mine ceramic coated from hedman and they don't have very much use on them and are rusting up in different spots..
Old Aug 28, 2014 | 12:22 PM
Axle/Gears: Stock
Yes they do.
Well that's you're problem there, hedman that is.
Old Aug 28, 2014 | 02:58 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
As I have learned from a different post, he wants perfection on a budget.
Old Aug 28, 2014 | 03:02 PM
DynoDave43's Avatar
Who doesn't?
If I can find a solid set used, I'm not against refurbishing them to save a few bucks.
But to Fasts point about budget...I'm inclined to wait and buy some DynoDon's when the time comes. Just want to be able to spot a bargain if I see it.
DynoDon....I like that name!
Old Aug 28, 2014 | 03:08 PM
Axle/Gears: Stock
Who doesn't?
Oooooh dons are pricy but i hear well built.
Old Aug 28, 2014 | 03:11 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
SLP once offered Tri-Ys with a matching Y-pipe that pop up every so often as well. They were very solidly built and offer great performance.
Old Aug 29, 2014 | 08:07 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Ive ran cheap $100 summit headers on several builds and they did well. Used copper gaskets and rarely ever had to tighten them.If you don't put a ton of miles on the car I think they would suit you well. And dang what a boost they add to these choked engines.
Hotrodboba400
Dec 10, 2019 07:07 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
Jlanz55
Sep 6, 2015 07:28 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
