91 camaro severe backfire
Old Sep 18, 2014 | 07:24 PM
irocwagon's Avatar
Car: camaro84.87iroc,91vert
Engine: Lt1, 383tpi,350tbi
Transmission: t56,T5,T5
Axle/Gears: 4thgenunknown,373,323?
91 camaro. 350 tbi,5spd
car was running fine, now it surges bad under hard acceleration,has severe explosive backfiring...unplugging the tan and black wire connector under the hood and the car is drivable,under acceleration check engine light cuts off then back on..codses 42 and 23..new coil, ignition module,plugs cap and wire
Old Sep 18, 2014 | 08:26 PM
irocwagon's Avatar
Re: 91 camaro severe backfire
Just took a ride .shifting under 2800 it runs fine..cruising at 50 with no isuues...but hard acceleration and the problems start
Old Sep 18, 2014 | 08:36 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Check your fuel pressure.....
//RF
Old Sep 18, 2014 | 09:43 PM
irocwagon's Avatar
new fuel pump,thought that was part of the problem
Old Sep 20, 2014 | 10:03 AM
irocwagon's Avatar
could a knock sensor cause these problems?
Old Sep 22, 2014 | 07:26 AM
torque_is_good's Avatar
does it occur when engine is cold, only in closed loop, or both scenarios?
Old Sep 22, 2014 | 11:08 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Check the pickup coil/ignition module connection for correct orietation. It is possible to reverse the pickup coil connection and have the module retard the timing on acceleration rather than advance it.
Old Sep 22, 2014 | 10:09 PM
irocwagon's Avatar
i thought it wouldnt start if reversed{pink and white wire?}
temp doesnt matter, does it always,closed loop also
Old Sep 23, 2014 | 01:27 AM
Schurkey's Avatar
Backfire out the throttle body (intake system) or out the tailpipe (exhaust system)?
Backfire out the exhaust may indicate misfire; the misfiring cylinder(s) push the full charge of fuel and air into the hot exhaust system, where it's ignited. Won't take much and the catalytic converter will be broken or melted. I've seen mufflers blown apart from exhaust backfiring due to a faulty diverter valve on the AIR pump, when the mixture went rich as the throttle closed, and the diverter valve dumped air into an overly-rich and hot exhaust stream.
Backfire from the intake system could be lean mixture still burning lazily on overlap, igniting the fuel/air in the intake manifold; or it could be wiped exhaust cam lobe(s) leading to excessive residual exhaust in that cylinder(s). Another possibility is a burnt intake valve leaking combustion gasses into the intake manifold.
If the vehicle was in my driveway, I'd be doing a compression test, cylinder balance test, and a leakdown test to verify valve sealing and equal cylinder power at idle. That also allows me to inspect the spark plugs. After that, it's Scan Tool time, looking for short- and long-term fuel trim abnormalities; or anything else in the data stream that seems suspect.
Old Sep 23, 2014 | 09:18 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Not sure where you are finding a white and pink wire. All the pickup coils I have played with are white/green wires. The pickup coil plugs in on the internal side of the distributor, not external. You have to remove the cap to access it.
Old Sep 23, 2014 | 11:21 AM
irocwagon's Avatar
ok,was thinking ignition not pickup.. thought you were talking about the wires on the outer,ill check under the cap,
its a massive backfire, seems like both, but deffi the tailpipe..only does it if tan and black wire is hooked up..
Old Sep 23, 2014 | 11:32 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
If the pickup coil is reversed the timing will be about 20-30* off and if memory serves me correctly the higher the RPM the greater the error and the worse it runs.
Old Sep 23, 2014 | 12:09 PM
irocwagon's Avatar
how do i determine if its installed correctly and not reversed other than swapping it around
Old Sep 23, 2014 | 12:11 PM
irocwagon's Avatar
also, the car starts every time the first time
Old Sep 23, 2014 | 01:28 PM
Schurkey's Avatar
Have you ever been inside the distributor to CHANGE the pickup coil wires?
If so, I'd be looking to see that the white wire was connected to the "W" terminal, and the green wire was connected to the "G" terminal.
Old Sep 23, 2014 | 04:05 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Connect a timing light to #1 plug. Open the EST/BYPASS connector and start the engine. Verify that the spark advance (SA) is at 0* BTDC (stock).
Turn off the engine and leave it at key-off. Reconnect the EST/BYPASS connector and start the engine.
Check the timing again with the light. The timing mark on the damper should now be more advanced then 0*, likely around 18* BTDC. This has the timing mark on the damper moving toward the passenger side of the vehicle.
If the timing mark on the damper moves toward the drivers side the pickup coil wires are backwards. I've seen this with brand new pick up coils.
RBob.
Old Sep 23, 2014 | 04:30 PM
irocwagon's Avatar
will attempt tonight..also new distributor and pickup, few months back
Old Sep 23, 2014 | 04:32 PM
irocwagon's Avatar
man im scared to reconnect that..last backfire it was in the garage when it happened,it knock the dust off the walls,went from being clean to complete dust covered
Old Apr 16, 2015 | 04:42 PM
88chevycamaro's Avatar
Car: 1988,1989 camaro
Engine: sbc 350 TBI
Transmission: 5 speed, th350 w/shift kit
Axle/Gears: 3:27
Any update on the backfiring? I seem to be having the same problem as you and cant figure it out...would apreciate some help!
Vintageracer
Jan 10, 2020 05:33 PM
MyRedCamaro
Dec 29, 2015 05:16 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
