Timing and driveability
Old Dec 19, 2014 | 11:34 AM
TheBallPlayer's Avatar
Car: 1990 Camaro RS
Engine: 5.0 TBI Edelbrock Intake
Axle/Gears: 3.73 Posi
Ok guys. Engine is a stock l03 with an edelbrock performer tbi, flowmaster exhaust, and some heddman longs, i just put the performer tbi intake on(ive ran it on my old engine). When i set the timing, the heat was on max. Would this explain the slightly sluggish engine? Im running in open look right now by the way, tune is untouched. WILL SETTING THE TIMING WITH HEAT ON HAVE A DIFFERENT EFFECT AS TO HAVING THE HEAT OFF WHILE I SET TIMING?
Old Dec 19, 2014 | 06:22 PM
Schurkey's Avatar
Re: Timing and driveability
I can't imagine an interaction between heater use and ignition timing.
Why are you in open loop? That can't be good. If the timing is set to spec, next step is to find out why it won't go into closed loop.
Old Dec 23, 2014 | 08:48 AM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Did you unhook the brown wire on the passenger side inner fender when you set it? If you didn't then your timing isn't set correctly.
ezobens
Aug 19, 2015 10:29 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
