More Power
Old Apr 6, 2015 | 01:43 PM
  #51
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: More Power
Originally Posted by gregl316
I think I have it.
I'll just stay with what you talked about earler.
Have the heads done to handle the 1:6 rockers &
the Hot Cam and save the money for the next build.
But I think I'll do the NoS just for fun.
Remember to start slow with that stuff. Once you install the kit spray fuel only the first time by not opening the bottle. Remember to pull about 2* of timing for every 50 HP you spray. I think for reliability issues I wouldn't cram more than 125-150HP into that setup. I also recommend a good RPM window switch set to kick in about 3,000 rpm and shut off a few hundred RPM below your shift point/rev limit and a WOT microswitch so that it sprays only at WOT or just let the EBL control it if you are running that.
Old Apr 12, 2015 | 07:00 AM
  #52
gregl316's Avatar
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
Re: More Power
I am not running an EBL rite now. I am going to have to get it tuned as soon as this is done.
I have the Cam, http://www.summitracing.com/parts/nal-12480002
timing change, http://www.summitracing.com/parts/clo-9-1157
the lifters, http://www.summitracing.com/parts/na, l-12371042
the locking plate, http://www.summitracing.com/parts/nal-12371042
Head gaskets, http://www.summitracing.com/parts/fel-1094
and intake gasket, http://www.summitracing.com/parts/mrg-136g
is there anything else I need besides the timing chain and water pump gasket?
the total comes out the $950 not bad for what it is and what I got. So basically I am making my motor a roller motor. That should free up some Hp.
I won't need to increase the size of the injectors? I know I'll need to bump up the Fuel pressure. The rest will be with the tune. What about using an EBL? I had one before but I couldn't get it rite so I sold it and had a chip burnt. Probably my bad and was no fault of RBob's as he bent over backwards to help me I just couldn't get it. Turns out to have been mech. issue that caused the tune to go in circles. I do admit it as in what the EBL does and can do was a bit over my head at the time. But I am willing to try it again.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
