will this cam work
Old Feb 24, 2015 | 01:11 PM
Poseidon's Avatar
Car: 1991 Firebird
Engine: 305 tbi Stock
Axle/Gears: 2.73 posi
will this cam work
I have a 89 305 firebird tbi what would I have to do to use
UPC:036584780564
Cam Style:Hydraulic roller tappet
Basic Operating RPM Range:1,200-5,200
Intake Duration at 050 inch Lift:210
Exhaust Duration at 050 inch Lift:220
Duration at 050 inch Lift:210 int./220 exh.
Advertised Intake Duration:264
Advertised Exhaust Duration:274
Advertised Duration:264 int./274 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.480 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.480 in.
Valve Lift with Factory Rocker Arm Ratio:0.480 int./0.480 exh.
Lobe Separation (degrees):112
Computer-Controlled Compatible:Yes
Grind Number:CS 264H-R12
I'm going to build a 350 later and reuse this cam
I also might throw 350 vortec heads on the 305 to use later to to help with flow I don't care to loose little compression pump gas car
Old Feb 26, 2015 | 12:06 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Re: will this cam work
Factory heads won't work with that much lift and its not worth having them worked over to accommodate the lift. You'd have to replace the entire top end, and at that point you may as well just wait a little longer and go straight to the 350.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Jake_92RS
Jan 28, 2020 10:37 PM
armybyrd
Dec 5, 2015 09:22 AM
camaro71633
Sep 1, 2015 10:24 AM
Fronzizzle
Aug 9, 2015 01:15 PM
