Doesn't seem to run on all cylinders
Old Jun 20, 2015 | 09:54 PM
Comicazy's Avatar
Hey guys. I'm really struggling with this camaro. Basic info, 305TBI, automatic.
So I've done a lot to get this car running, injectors, plugs, wires, cap, rotor, ign module, fuel pressure regulator and iac valve.
So here's what's going on with it. Upon first starting, it will Rev up and down constantly, and occasionally stall out. I thought the iac valve would fix that, but no dice. After running it for a while, the idle will smooth out and hold around 1k. Sometimes I can hit the gas and with only a slight hesitation, it will Rev up no problem. Other times, it bogs down and almost dies. I've also tried driving it, and as soon as I put it in gear and give it gas, it stumbles. It just seems to have absolutely no power, and then out now nowhere it will just jump right up and take off. It's almost like at times it's just not running on all cylinders, then intermittently it does. The check engine light did come on this last time and I read the codes off it.
12- This just seems to indicate that the diagnostic program is working correctly.
14- Coolant temp sensor error(low temp)
22- TPS signal low
34- MAP sensor(signal low vacuum high)
44 - Left bank O2 sensor lean condition
Now the TPS code was probably thrown because I disconnected the sensor to see if it changed how the car ran. And the Coolant temp sensor was Jerry wired when I got the car, so that may be what's causing that to come up. Other than that, what do you guys think? Thanks.
Old Jun 21, 2015 | 05:31 PM
ex-x-fire's Avatar
Re: Doesn't seem to run on all cylinders
Low fuel pressure.
Vacuum leak, tbi base gasket is usually blown out.
Bad egr solenoid, causing the egr to get vacuum during idle or starting of engine.
Old Jun 23, 2015 | 11:39 AM
Poseidon's Avatar
Car: 1991 Firebird
Engine: 305 tbi Stock
Axle/Gears: 2.73 posi
i had the same problems i changed the rubber line on the fuel pump it would suck air once low changed the fuel filter replaced the map sensor and it was fixed. If you can try a new map it would probably fix most of your problem
Old Jun 24, 2015 | 10:57 PM
Schurkey's Avatar
22- TPS signal low
Fix the CTS wiring, clear all the codes, see what comes back.
Old Jun 26, 2015 | 07:01 AM
Wife'sCar's Avatar
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
This ^^^^^^^ the computer diagnoses engine condition with the coolant temp sensor, if it's not getting an accurate reading within normal spec then the computer freaks out and causes the car to run in the safest possible conditions to keep itself alive, which is terrible for performance and fuel mileage.
NinjaNife
Aug 23, 2015 11:49 AM
db057
Aug 22, 2015 08:17 PM
redmaroz
Aug 16, 2015 11:40 PM
Randomtask2
Aug 13, 2015 01:57 AM
Sherpajames
Aug 7, 2015 06:56 PM
