persistent 305tbi issue, please help!
Old Sep 11, 2015 | 01:56 PM
  #51
92firebirdguy's Avatar
Car: 92 firebird
Engine: 305 tbi
Re: persistent 305tbi issue, please help!
i dont have a scan tool only a multi meter and all those ideas need a scan tool
Old Sep 11, 2015 | 04:18 PM
  #52
Car: 92 firebird
Engine: 305 tbi
anyone else? still tackling this issue and need ideas of what to check
Old Sep 15, 2015 | 06:09 PM
  #53
Car: 92 firebird
Engine: 305 tbi
no one else here can help me at all out of the thousands of people on here only 1 person has an answer???
Old Sep 15, 2015 | 08:14 PM
  #54
two-if-by-sea's Avatar
Car: 89 RS Vert, 89 Formula, 89 Bird
Engine: L03, TBI 350, none
Transmission: 700R4, 700R4, none
Axle/Gears: 3.42, 3.45, none
My '89 TBI with 70K miles got so bad, I had to slip it in neutral when I approached red lights before stopping, else it would die. And it happened quickly; week before, the car ran fine, 5 days later it was almost impossible to drive. I did all the stupid sensors, cap, plugs, etc... no change. Finally threw in the towel and took it to a mechanic. Issue was the distributor. Good luck finding your gremlin.
Old Sep 15, 2015 | 09:06 PM
  #55
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Ever check that fuel pressure? Another thing you can do is observe your fuel injectors and ensure your getting an even conical spray pattern from both. If not, your may want to replace the injectors filters/0-rings and fuel pressure regulator diaphragm. Any leaking fuel around the throttle body or strong smell of gas?
Old Sep 15, 2015 | 09:14 PM
  #56
Car: 92 firebird
Engine: 305 tbi
Thank you for your reply, how do I test the fuel pressure on my motor?
Old Sep 15, 2015 | 09:15 PM
  #57
Car: 92 firebird
Engine: 305 tbi
My entire ignition system has been updated and replaced recently. All parts on my ignition test 100% good.
Old Sep 15, 2015 | 10:11 PM
  #58
antares57's Avatar
The correct way is to purchase an adapter, install in-line with the feedline and attach a fuel pressure gauge to it while cranking and running. Next would be to be to observe fuel injectors to see whether they are spraying correcting or just dribbling/or pouring fuel into the throttle body while running.
Old Nov 16, 2015 | 07:12 AM
  #59
spoazzy1's Avatar
Car: '89 Firebird
Engine: 305 TBI V8
Axle/Gears: Stock
I'm having the exact same issue. Only thing that hasn't been replaced yet is the EGR and solenoid. 92firebirdguy, have you fixed it yet? Just curious what the cause is for you? I was idling high, almost like the Throttle was sticking. I pulled the throttle body, overhauled it with new gaskets and the works and now it's doing this when I stop, just stalls? It's fine when cold, but once it warms up, poof. I have a new IAC and TPS is set correctly, all vacuum lines are brand new, my ignition system is all new (wires, plugs, cap, rotor). I also put on a new fuel filter. I'm just stumped. Still keep pulling a code 33....
Old Sep 1, 2016 | 07:53 AM
  #60
teddy61's Avatar
Car: 1988 g92,j65,mm5,dx3 convertible
Engine: 5.0 tpi
Transmission: T5 world class
Axle/Gears: 9 bolt 345 australian disc posi
alright ill give it a shot. any other ideas if it ends up not being a vac leak?
Check your heater control switch in dash it's vacum operated mine was leaking vacum I pulled the hard plastic line off my engine and plugged it and my miss went away everybody always forgets to check that because it's under the dash lol
Bubbajones_ya
Jul 6, 2024 08:32 PM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
