TPI to TBI
Old Nov 20, 2015 | 10:04 AM
RedIrocZZ's Avatar
Car: 1986 Camaro IROC-Z
Engine: 350 C.I.
TPI to TBI
What would I need to do to make my Camaro a TBI? It is currently a TPI.
Old Nov 20, 2015 | 10:07 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: TPI to TBI
The reverse of this..........had to do that!
https://www.thirdgen.org/forums/engi...hlight=TBI+TPI
Old Nov 20, 2015 | 10:12 AM
Twin_Turbo's Avatar
Re: TPI to TBI
WHY?
Old Nov 20, 2015 | 06:04 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Re: TPI to TBI
^^X2.
Old Nov 21, 2015 | 12:16 PM
88RS's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: lt1 10 bolt 3.23
Re: TPI to TBI
Why not? TBI is a simpler. cheaper system to modify for performance.
Old Nov 21, 2015 | 12:53 PM
Twin_Turbo's Avatar
TPI to TBI
It's no simpler than tpi. Just less inhectors. How do youcheaply get more performance out of it trumping the tpi?
Old Nov 21, 2015 | 01:30 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Re: TPI to TBI
It may be simpler to tear apart and work on, but you'll seriously limit your power potential with it. It's good for a daily driver but for performance not so much. Why not a stealth ram or pro flow intake?
Old Nov 21, 2015 | 02:03 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TPI to TBI
They aren't TPI. The OP never stated his goals.
RBob.
Old Nov 21, 2015 | 02:07 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Re: TPI to TBI
Not specifically no, but he did hint at "modifying for performance".
Old Nov 21, 2015 | 02:14 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TPI to TBI
Is this the '86? If so it is easy, EFI wise need to move a few terminals/wires in the ECM harness connectors. Add a MAP sensor and wire it in (use the MAF wires). Under the hood, change the injector connectors, and possibly the TPS & IAC (they vary) connectors.
Swap the intake, be aware of the TBI intake having the newer mounting bolt angles (4 bolts).
RBob.
1988_f-bird
Nov 13, 2015 06:48 PM
oneleglance
Nov 6, 2015 06:19 PM
C-wade7
Nov 3, 2015 01:10 PM
ev305tpi
Nov 1, 2015 03:58 PM
F-Jape
Oct 31, 2015 12:05 PM
