91 camaro passenger injector dont work
Old Dec 22, 2015 | 02:17 PM
upholsteryguy's Avatar
I have to prime the car for it to start. Once started it will stay running. While running passenger side injector don't work. I ohme tested tbi injectors at 1.5 each. Did battery test and injectors clicked. I tried a noid and no power to injector. When I start the car some times won't turn over. When I turn the wheel or just turn ignition back and fourth for it to finally turn over. Any solutions?
Old Dec 22, 2015 | 02:37 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: 91 camaro passenger injector dont work
Check injector fuses first. Sounds like one may be toast. Try swapping harness from good injector to the other, see if it comes on.
Old Dec 22, 2015 | 02:41 PM
Schurkey's Avatar
https://www.thirdgen.org/forums/tbi/...ml#post5989894
Old Dec 24, 2015 | 10:48 AM
Thanks I'll check the fuses...I've swswapped injector harness and then the passenger side one works and the drivers side don't then. I'll check the fuses..thank you
Old Dec 25, 2015 | 06:41 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Both injectors use a common fuse for +12Volt. Instead, check the negative side of the circuit that connect injectors to the ECM. Injector circuit uses larger diameter wire (smaller AWG) - check harness for a broken wire or a loose connection at ECM plug. Check ECM plug Pin D14 and D16 - these pins may have an intermittent connection to a harness.
If you are unlucky your ECM may have suffered internal failure in the injector circuit. It is rare, but it does happen.
//RF
Old Dec 27, 2015 | 10:21 PM
Thanks I checked the fuses and inj. 2 fuse didn't have a fuse in it...that was an easy fix...thanks
321FormulaGuy
Nov 13, 2015 06:10 PM
Veaceonee
Nov 13, 2015 11:40 AM
Batwill
Nov 13, 2015 09:48 AM
oneleglance
Nov 6, 2015 06:19 PM
cowboysfan20
Nov 5, 2015 12:46 AM
