Cheap way to free up power?
Old 02-25-2016, 01:07 AM
speedking1995's Avatar
Car: 1992 camaro rs 25th anniversary
Engine: 305 TBI
I've been seeing deletes for everything lately and I've been wondering, what can I do to free up some power on my car? What "deletes" will make a difference? I have a 1992 Camaro RS with a 305 TBI, thanks in advance
Old 02-25-2016, 03:56 AM
Schurkey's Avatar
Re: Cheap way to free up power?
Virtually nothing that's going to be legal.
Old 02-25-2016, 03:06 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
You can delete the AIR system, but it won't gain you much. Biggest restriction on that motor stock is the exhaust system, but you'll be limited by the heads pretty quick after you do an exhaust.
Old 02-26-2016, 02:07 AM
Engine: 305 TBI
So if I end up deleting the AIR system what will I need to do other than take the pump out, I've seen others use shorter belts rather than a delete pulls (which I would prefer) but is there a downside to it? There's no emissions testing here, so I'm not worried about that, but will it run fine? Any info is greatly appreciated, thanks in advance
Old 02-26-2016, 08:51 AM
Street Lethal's Avatar
Pulling the air pump accomplishes nothing other than reduces clutter, so leave it on. A larger exhaust will do nothing with the amount of horsepower you are currently making, other than sounding better. If you're not going to invest in heads/cam, and you are just looking to free up a little power with what you got, then focus on freeing up the air coming into the engine and keeping it cool throughout. You can also tweak your spark tables, and maybe even your cam timing. Other than that, your not going to find any real power doing anything else. Meaning, so long as your engine is getting enough fuel for the air it is ingesting, then it is what it is, unless you increase that air...
Old 02-26-2016, 08:55 AM
Read the sticky in the exhaust forum, covers it pretty well. You'll need to remove the pump, lines, plug up any holes in the exhaust system, & re-route your belt & get a different length belt.
Clay_T
04-07-2016 07:19 PM
LsxMatt
Exterior Parts for Sale
02-25-2016 12:11 AM
ndevin25
02-04-2016 10:27 PM
Isaac McCormick
02-04-2016 08:52 AM
mrestrictrplate
01-31-2016 03:47 PM
Quick Reply: Cheap way to free up power?
