TBI superchangers....
Old Dec 31, 2001 | 12:20 PM
TBI305Camaro's Avatar
i got to looking and wouldnt any blower that works with a carb work with a TBI if you use the adapter plate?
Old Dec 31, 2001 | 12:42 PM
fast_broker's Avatar
Yep. Just the serpentine belt acessory drive package that's the problem... And the associated 2-bar MAP sensor and PROM work required to get it RIGHT, but none of that is a big deal...
Old Dec 31, 2001 | 01:26 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
When I was at summit, they had a procharger hooked up to a holley carb by just incasing the carb with a metal housing with a tube runnin' to the blower. It was pretty trick, I figure it'd fit tbi perfect...
Old Dec 31, 2001 | 03:55 PM
Tas's Avatar
Tas
The new summit catalog has some good weiand/holley 144 blowers. They brought the price back down because of the resession I think. Or maybe no one was buying them when they raised the prices last time
Old Dec 31, 2001 | 09:47 PM
what kinda horsepower would the holley 144 add to a slightly modded 305 tbi? if you were gonna do something like that wouldnt it be a good idea to either get bigger injectors or a holley TBI unit? also dont the blower like that take place of the intake manifold?
Old Jan 2, 2002 | 08:27 AM
I don't believe that those blowers work with serpentine belt packages, yet. They were suppsoed to get a longer nose blower for TB's but since they already have a TBI blower for a truck, they probably won't do anything else untill they see demand.
I'd buy one for $1500 or less, FOR SURE!!!
Old Jan 2, 2002 | 10:34 AM
ive looked at every site i can think of for the TBI superchargers for trucks...anyone know a site that has them??
Old Jan 2, 2002 | 10:47 AM
Nitroburn's Avatar
Holley's website has it...
http://www.holley.com/HiOctn/ProdLin...-144_CSBE.html
Old Jan 2, 2002 | 11:48 AM
It's like $3k for trucks, I think. ouch
That's a lot of money for something that wears out so fast.
Old Jan 2, 2002 | 11:58 AM
Nitroburn's Avatar
Yeah...for that kind of money, I think I'd rather get a 6-71 blower and figure out how to put two TBI's on it!!! More boost, less money! So what if it sticks out of the hood a little bit <hehehe>
Old Jan 2, 2002 | 12:08 PM
thassright
Old Jan 2, 2002 | 02:38 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Shane Buss did this, he bought that blower for 86 tbi trucks, bolt on deal, he had to get a different hood though. Dont need a 2 bar map sensor either since the TB is before the boost. Seen it several times in fact they sell the kit with a "custom" chip so its pretty much a bolt on deal for any schmo with a tbi pickup truck. One of the mags had a how-to on it a little while ago
Old Jan 2, 2002 | 02:39 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
and i could swear he paid 1500 for the setup
Old Jan 2, 2002 | 02:46 PM
Tas's Avatar
Tas
The one for serpentine belts is $1709 in the new summit catalog. But the TBI ones that are 50 state legal do start at $3k. they add $1000+ just for their legality. I wonder if their legality even extends to fbodies since they are for TBI trucks.
Old Jan 2, 2002 | 02:48 PM
whats the P/N of the one in SUmmit for $1.7k??? I thught they had one for PARTIAL serpentine packages, not entire versions???
FYI, I'd still run a 2-bar MAP sensor AFTER the blower as the vacuum sensed before the blower wouldn't always correllate (sp) with actual boost being seen by the engine. ie MAP readings before don't always correlate to the same MAP 2-bar readings afterwards... Just the evil of blowers, plus, when/if the blower decays over time, you'd have to change the prom bit-by-bit to make up for the loss of boost correlation as well.
How about FastBurn/Vortec versions?????
Old Jan 2, 2002 | 02:49 PM
couldnt i use the serpentine belt setup even if it is for carb? just use an adapater plate right?
Old Jan 2, 2002 | 03:15 PM
Tas's Avatar
Tas
http://store.summitracing.com/search...earchtype=both
It doesn't say anything about vortec heads but if the ports are big enough you should be able to work something out like Shane B. did on his since he has Vortec heads and a weiand.
The dedicated TBI ones are: hly-77-144csbe-1 and the polished version on it is hly-77-144csbep1 I think they do use a carb to TBI adapter plate like the old B&M roots charger packages had. They should also have EGR in the front like the Old B&Ms since Holley bought them out.
http://store.summitracing.com/search...=14&search.y=6
http://store.summitracing.com/search...x=5&search.y=7
Old Jan 4, 2002 | 04:27 AM
4-bolt's Avatar
I was just on Jeg's website and the 144s start at 2099.99. Much better than 3K
Old Jan 4, 2002 | 08:21 AM
I just bought some E-Tec 200's from JEg's. Let's see how they compare to the other motor with FastBurn's I have. It'd be nice to get a blower NOW instead of buying an intake/brackets/etc taht I'll just sell in 2 months, anyway. OR I should do the MPFI I keep talking about... hmmmm
Old Sep 10, 2004 | 04:32 PM
25THRSS's Avatar
Is this kit still available?
Old Sep 10, 2004 | 10:09 PM
ReddyK's Avatar
Car: 86 Z28
Hi,
I have a Procharger supercharger on my 95 TBI suburban and I don't see any reason it wouldn't fit a camaro. The innercooler ducting would have to be different but thats all I see.
Hope this helps,
Steve
Old Sep 10, 2004 | 11:18 PM
25THRSS's Avatar
Originally posted by ReddyK
Hi,
Hope this helps,
Steve
Thanks for the info, but I am looking for a roots style blower. I prefer them over a blow thru system on tbi. So far the closest thing to a bolt on roots blower for tbi cars is the Weiand 93-95 GM TBI truck blower.
Old Sep 11, 2004 | 12:41 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
not true. the SHORT version standard weiand blower, will work with the serp belt setup. it needs like a 1/4" spacer on the pulley. Do a search in the power adder board. There was a guy running one, fit almost perfect.
Old Sep 11, 2004 | 12:47 AM
25THRSS's Avatar
I don't really like this setup, as the blower is run off of the same belt as all the rest of the pulleys and would require either sacrificing driveability of the accessories or performance of the supercharger. With the extra long blower you can run each individually. And by bolt on, I meant an entire kit, not throwing all kinds of things together to try and make it work ok and hack everything up.
EDIT: BTW, I saw that post and was interested in the pics, but they won't work anymore.
Old Sep 11, 2004 | 11:32 AM
Dewey316's Avatar
Car: 1990 Camaro RS
well, i would consider only making a 1/4" spacer, about as close to a bolt on as you can get. giving it its own driver pully is a nice route to go, but you only have 2 choices then, the much more expensive TBI Truck version of the 144, or you get to deal with much more fabrication to get the 142 long nose to work with serp belts.
Old Sep 13, 2004 | 11:15 AM
frogmanjohn's Avatar
Car: 89 RS
Engine: 305 TBI 215,000+
they also have the whipple twin screw supercharger for the 305 tbi truck, i don't see why it wouldn't work for us.
john
Old Sep 13, 2004 | 01:42 PM
25THRSS's Avatar
john
It would work, but I don't much like that design either as the throttle body mounts horizontally and just doesn't seem like a good idea to me.
Old Sep 16, 2004 | 02:51 PM
Ronny's Avatar
i ordered the procharger catalog. the bonnet has excellent hood clearance. sits 2.00 inch above TB. flows 1200 cfms. uses serpentine. about $2000 retail. i like it.
Old Sep 16, 2004 | 11:53 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
how would the computer take to the extra air coming in from the supercharger?
Old Sep 17, 2004 | 06:07 AM
Dewey316's Avatar
Car: 1990 Camaro RS
it does, it treats zero vacume, as zero vacume. you need some some of boost referenced fuel pressure regulator, so it adds X ammount of fuel per psi of boost. (not to be confused with a vafpr, they are completely diffrent)
Old Sep 17, 2004 | 10:30 AM
ThraxXx's Avatar
ah ok. Then I think I am gonna investigate this further cuz I would love to supercharge my 305
Old Oct 3, 2004 | 11:36 AM
parks911's Avatar
Car: 91 Camaro RS
Engine: 350 Police with some MINOR modifica
Transmission: kitted 700R4 & vette servo
Ships tomarrow for $1799.00 + S/H.
http://store.summitracing.com/defaul...earchtype=both
Old Oct 3, 2004 | 01:15 PM
James Montigny's Avatar
Keep us posted, I'd love to see the buildup
Old Jul 19, 2008 | 08:22 PM
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
Re: TBI superchangers....
Summit no longer has the Holley part number, its under Weiand. The Part number is 77-144-CSBE-1
http://store.summitracing.com/partde...00+&rsview=sku
Best part is that its designed to fit the OEM TBI. I'd bet that with very little work you could get it to fit the 670 Holley TBI.
Old Aug 29, 2008 | 12:51 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Did you realise this thread is 4 years old?
Old Aug 29, 2008 | 01:52 PM
Ronny's Avatar
Parks car sold 4 times by now. He prob driving a Nissan!
Old Aug 29, 2008 | 06:14 PM
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
Yes I did, but only after I hit the "Submit Reply" button
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
