Longer Oil Filter - Why Not?
Old Jun 5, 2017 | 02:22 AM
Triton_330's Avatar
Car: '89 Camaro RS (White ext./Red int.)
Engine: 305 TBI (aka the L03 5.0L V8)
Transmission: Stock Automatic (A4)
Axle/Gears: Stock (2.73)
I found a picture on here posted by KRUSS back in 2007:
https://www.thirdgen.org/forums/afte...ml#post3406534
It's showing an AC Delco PF1218 (a 5 inch long filter) installed on his '92 Camaro with a 305. As you can see in the image, there's a good 4 inches between the bottom of the filter, and the bottom of the oil pan, which means there is room for a filter of 9 inches long without any ground clearance issues.
The AC Delco PF932, and multiple other equivalents which are around 8 to 9 inches, should therefore be able to fit without problem.
Does anyone have any reasons as to why one shouldn't run this 2 quart filter on a Camaro? It is the same thread size, gasket size, and everything, as the PF454 and PF1218, just longer.
https://www.amazon.com/ACDelco-PF932-Professional-Engine-Filter/dp/B000C9QDNM https://www.amazon.com/ACDelco-PF932-Professional-Engine-Filter/dp/B000C9QDNM
(I'm posting this in the TBI section because I would be installing it on my 1989 Camaro RS with the 305 TBI, so I hope this is the correct section.)
~Triton
Old Jun 5, 2017 | 09:27 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Longer Oil Filter - Why Not?
I have been using the K&N-3002 for a long time now.
Old Jun 6, 2017 | 02:20 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I also use the taller filter.
Mobil 1 Extended Performance M1-302.
Just be sure you "prime" the filter before you put it on.
My filter will hold around a Quart of oil.
Old Jun 6, 2017 | 06:29 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I use taller wix racing filters
Old Jun 6, 2017 | 08:03 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
I have used the longer (2-qt) truck oil filter on my 87 IROC-Z28 since its first oil change over 30 years ago with no problems.
Old Jun 6, 2017 | 11:41 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
What part #?
Old Jun 6, 2017 | 11:51 AM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Wix 51060R
Great filters.
Old Jun 6, 2017 | 05:24 PM
82tarecaro's Avatar
I have been using the longer truck filter since the original PF25 was replaced by the PF454. I believe it is the PF1218, which is about the same size as the old PF25.
Old Jun 6, 2017 | 08:12 PM
nhgator's Avatar
Car: 1985 T/A
I have been using them too,in a bind if the parts monkey is younger than 35 just ask for one for a 1970 pickup with a 350.
Old Jun 6, 2017 | 09:03 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Wix Racing has less filtering capability than standard Wix. Fine if you're racing, because you tear your motor down more often.
Old Jun 11, 2017 | 09:28 PM
Engine: TBI,5.0
I just like the Mobil 1 Extended Performance Products.
I have been using them for a long time.
Old Jun 12, 2017 | 05:43 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
2 reasons: one, I blew up an L69 the first time I tried the long filter. Added extra oil and the engine was strong. Yeah, I know.
Second, I have multiple vehicles that fit, or require clearance for, a PF3980 filter. So I make it easier to shop for one filter, instead of a few, by changing the adapter.
Old Jun 13, 2017 | 06:43 AM
TTOP350's Avatar
Or change your oil more often but that's kind of why I didn't give out the part number for the filter I use.
Old Jun 13, 2017 | 03:34 PM
thtanner's Avatar
Originally Posted by thtanner
Wix 51060R
Great filters.
Just remove the R for the non 'race' filter.
Old Jun 13, 2017 | 04:00 PM
DJP87Z28's Avatar
No one as mentioned the benefit if the additional quart of oil added with the long (2-qt) filter. For me that additional quart with out adding a larger oil pan is major for me.
Old Jun 13, 2017 | 04:46 PM
jmd's Avatar
jmd
I would say the benefit of that qt. is questionable.
There's no cooling added. Given the choice between the long filter and a cooler, I'll take the cooler.
The short filter has plenty of surface area for filtration, unless you're driving through dust storms.
Assuming someone has an engine in good condition, and maintains it well, the big filter isn't going to help a thing.
Old Jun 13, 2017 | 11:59 PM
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
It may not help any, but it surely doesn't hurt I would think. I've also been using the longer filters for years. Recently found out the LS motors are the same way. Was at the parts store a few weeks ago getting oil and filters for the suburban and the wife's avalanche. Suburban has a 6.0 and the avalanche has the 5.3. Dude brought out 2 different filters. The 6.0 filter is longer. Just got 2 for that motor. Since both trucks are high mileage (suburban 400k, avalanche 200k) and use about a quart between oil changes, I look at it as I have an extra half quart when the low oil level light comes on
Old Jun 14, 2017 | 02:56 AM
Engine: TBI,5.0
I just can put that little 3 inch tall filter on my Chevy Small Block V-8.
Feels like a toy in my hand.
A little 4 banger maybe.
Old Jun 15, 2017 | 06:21 AM
3rdgenmaro's Avatar
Car: 88 IROC
Not sure I agree with that logic. Total system volume has increased true, but oil depth in the bottom of the pan and in relation to the oil pickup has remained the same.
Old Jun 15, 2017 | 09:30 AM
Not sure about other brands, but the longer filter (KNN-3002) has an anti-drainback valve in it whereas the normal length (KNN-2002) does not.
Old Jun 15, 2017 | 09:45 AM
Lurbie's Avatar
Car: 89 Camaro
I'm with you on this. Extra oil somewhere else doesn't change the depth of the oil pan, height of the oil pickup, or height of the oil level sensor.
Old Jun 15, 2017 | 09:47 AM
Lurbie's Avatar
Car: 89 Camaro
Which is useless when the oil filter is vertical. This would only be helpful if using a remote oil filter location and the filter is horizontally oriented (or upside down, but who would do that? )
Old Jun 21, 2017 | 12:33 AM
Engine: TBI,5.0
( I'm with you on this. Extra oil somewhere else doesn't change the depth of the oil pan, height of the oil pickup, or height of the oil level sensor. )
That sounds right..
The main reason I like the larger filter is , lets say you have 6 qt. of oil in your car rather than 5 .That means you are filtering 6 qt. of oil during rotation of the oil through the system.
That's the hole point of the larger filter. To give you the extra qt.
Old Jun 21, 2017 | 06:55 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
I use Fram Extra Guard filters and a PH30 PN. Does anyone know if they make or use the larger filter. If you do do you know the PN? I have been wanting to use the larger filter also.
Old Jun 27, 2017 | 11:49 AM
Schurkey's Avatar
1. Not a "2-quart" filter.
2. No reason you can't run it. I install the taller filter whenever I don't have clearance issues. It's been done for decades. Won't hurt a thing. I also install the "long" 5" 1049 NAPA filter on some AMC, old Buicks and old Cadillacs, Intercoursibles, Olds, Pontiacs, and Rutebagas, if there's clearance. There often isn't clearance on newer Buicks, and I don't see a lot of AMCs, Internationals, or Studebakers.
3. Does not provide "better" filtering. Goes longer before getting plugged/restricted. The shorter filters probably provide some cost-savings to GM when installed by the millions--shorter, less-expensive filter to make, and you don't need the extra half-a-quart of oil to fill like you do with the taller filter.
Provide a part number for your "2-quart" "Truck" filter. Does it REALLY hold 2 quarts?
As said, having more oil in the filter doesn't help the engine much. There's a little more surface area to radiate heat, and the oil filter element will go longer without plugging...but that's of little concern to us since folks tend to over-change the oil and filter. Sixty+ years ago, some folks only changed the filter every other oil change, and of course the engines created more sludge and ingested more dirt via gravel roads and the "screen" on the crankcase ventilation system back then anyway.
I think these people's heads will explode if you are actually talking about the Wix/NAPA 51794/1794 genuine medium-duty TRUCK filter. (Nearly 8" tall, over 2 1/2 inches taller than the "tall" filter these guys are talking about.) They're made by all the usual competing companies as well.
I'm fairly sure there's a still-taller filter that will screw right onto a typical Chevy V-8 oil filter adapter, but I can't find a part number. I haven't seen one in thirty years, so my memory may be fuzzy, but I remember thinking it was a foot long or more.
Old Jun 27, 2017 | 01:06 PM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Im the 2nd owner, 135k on L98, been using cheap off brand oil and filters since the 1st oil change back in 1991 (im friends with the OG owner). runs great, 150psi compression in all cylinders, plenty of power to smoke the tires, did intake gasket last weekend, still looked super duper in there.. change your oil/filter regularly
, dont fall for the hype.
