5.7L TBI Rebuild
Old Jan 4, 2002 | 05:11 PM
Silverado5.7L's Avatar
5.7L TBI Rebuild
Hey I'm in the middle of rebuilding my TBI. I have the kit from Autozone.
Other then the rebuild is there anything I should do before I put everything back together?
Matt
Old Jan 5, 2002 | 12:24 AM
JPrevost's Avatar
Car: 91 Red Sled
How about making the fuel pressure regulator adjustable! On my website there is an awesome tech article made by Vader. It's a pdf (adobe acrobat reader format) and has lots of pictures and very detailed. It's a really good idea to adjust this if you already have the TB unit off the car. Also be sure you reassemble the spring the correct way and be extra careful with the rubber gasket for the fuel pressure. Other than that it's really easy. Just like a prefab lego toy, screw together and install, check for leaks, no leaks, keep driving :-)
Old Jan 5, 2002 | 02:10 AM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
Don't forget to shave off those ridges around the throttle bores
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
BAMiller
Sep 14, 2015 06:38 PM
sylentnite
Sep 9, 2015 02:55 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
