can LT4 springs fit on L03 heads?
Old Jan 4, 2002 | 09:09 PM
Tallboy's Avatar
wondering if lt4 springs will fit on L03 heads?
a guy is selling them never used 4 about 30 bux?
what do they go 4?
Old Jan 5, 2002 | 11:03 AM
TBI305Camaro's Avatar
if they wont fit summit sells alot of different springs for around 40 bucks...
Old Jan 5, 2002 | 01:48 PM
NJ SPEEDER's Avatar
the big problem isn't really if they will fit into place or not. they will. the real issue is that they are a lighter weight spring. the LT4 came with light weight valves and therefore require less spring. if you put lighter springs onto our stock valves it will cause a lot fo float very early in the rpm band.
like he said, $40 for a good set that will get he job done.
later
tim
Old Jan 6, 2002 | 09:41 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
not to change the subject buti am going to replace valve springs soon too.. would lt1 valve springs be better then lt4??
Old Jan 6, 2002 | 09:51 AM
bbtaz97's Avatar
Car: 91 RS
ive got a 96 lt1 cam with 1.52 rocker arms witch would produce a lift of about .480 or so... so if anyone hase some part numbers if lt4 springs arent good..
customblackbird
Aug 15, 2021 10:16 PM
Jake_92RS
Jan 28, 2020 10:37 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
