CFI EBL Tuning - Shut Off Forced Open Loop?
Old Jun 22, 2018 | 08:18 AM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Quote from Dynamic EFI tuning guide - "You can un-check the forced open loop during decel option to do a VE Learn." Can anyone direct me to where I would do this in Tunerpro, obviously I can't find it. Thanks.
Old Jun 22, 2018 | 10:57 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: CFI EBL Tuning - Shut Off Forced Open Loop?
Option flag:
Option Word 3 - Bit 5 - OpDcl
RBob.
Old Jun 22, 2018 | 01:00 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Thanks, one more quick one while I may have your attention - this is what I'm tuning -Specs - 383 Stroker, Comp Ratio ~10.5:1,
Speed Pro Cam - Valve Lift .454 Intake & Exhaust @ .05 - Lobe Sep 110° - Duration 218° I&E,
80# Injectors, Aluminum Heads 64CC - 245 @. 450 Lift,
High Pressure Fuel pump set at 24#'s,
Ext Variable Vac referenced fuel pressure regulator
Renegade manifold
long tube headers (headman)...
Which SA table in your BIN files should I start with?
Old Jun 22, 2018 | 01:16 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
You might want to list if your using a automatic or manual transmission.
Old Jun 22, 2018 | 02:55 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Oops - auto 700R4
Old Jun 22, 2018 | 05:51 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Set up two BINs, one with the SA tables from 3001, and the other from 3006. Flash each into a bank and try both.
Can easily switch between the banks while out driving (pull over to do the switch).
RBob.
Old Jun 23, 2018 | 11:41 AM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
RBob.
As usual thanks for the excellent support. Did that and ran into what I assume is an unrelated issue. I'm not getting any learns while in WB learn mode. It does show learns if i switch to NB though. Also I'm getting the following message on VE Learn screen - "BLM not at 128 while in WB learn mode Force open loop mode".
Can you suggest resolution? Thanks.
Old Jun 23, 2018 | 12:31 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Disable closed loop by setting the enable temperature high.
RBob.
Old Jun 23, 2018 | 12:53 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
RBob.
I'm confused don't I have to be in closed loop to get VE WB learns?
Old Jun 23, 2018 | 01:18 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
No, only for BLM learns. WB learns require open loop, otherwise the fuel trims come into play.
RBob.
Old Jun 23, 2018 | 04:06 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
RBob.
thanks makes sense
Old Jun 25, 2018 | 11:40 AM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
deleted
TheGoatchrist
Mar 20, 2013 03:32 PM
kataklysm01
Oct 20, 2011 02:33 PM
pandin
Sep 11, 2008 09:25 AM
